0 Members and 449 Guests are viewing this topic.
Zeitmaschine
Quote from: v8karlo on August 17, 2012, 02:10:48 PM
His device has pulsed direct current output. In that video he attached car battery directly to
output of his device.
What video could this be? Can't remember seeing any car battery connected directly to the output of the TK device.
Quote from: yfree on August 17, 2012, 02:08:59 PM
Bulbs do not need 220V/50Hz to light up, as long as they get the power they need. The output of the tin can is pulsed and not necessarily 50 Hz.
Then if 220V/50Hz is not needed, what is the blue box inverter for? If the output is pulsed TK could run his device directly with the car battery.
27Bubba
@V8Karlo
"Wires are litz from ordinary 3PL house cable, its cheap and you can buy them for nothing."
Do you mean litz wire as this one:
http://en.wikipedia.org/wiki/Litz_wire
Or common multi strand wire? Thanks.
leo48
QuoteWhat video could this be? Can't remember seeing any car battery connected directly to the output of the TK device.
Here:
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
yfree
Quote from: Zeitmaschine on August 17, 2012, 03:00:39 PM
Because TK constructed the device such as to be able to power it either directly from the mains or from the battery through an inverter, or in a loop; from the rectified output of the device through an inverter.
Free.Energy
V8karlo
try to charge capacitor with one side to ground and other to metal plate near coil setup
If is back and forth use bridge rectifier between plate and capacitor
