Hoppy
Quote from: valibb on August 18, 2012, 12:15:25 PM
It is posible to output power of the aquarium to be 700-1000V. I think, it is posible the heater to be modified. In normal condition, all three heater elements are put in parallel, but if you put elements in series you need high voltage. Hallogen heater use 30% less energy then normal heater.
The same is for bulbs. Hallogen elements have more fiabillity than normal elements. You can use over tension than normal use due higher resistivity. Nobody see how are bulbs connected in TK previous movies. Of course clampmeters indicate high amperage, but clampmeters can be easily manipulated to show what you want to show(more or less).
   This is why TK don't his invention to illuminate his house, he need to put in series more bulbs and interrupters will be destroyed afer first or second use.
And of course don't forget the inductance of heater elements...
Good points raised here. In the absence of hard data on the electrical characteristics of the heater / lamps, leaves it down to pure speculation as to exactly what is driving the load.
Hoppy
wattsup
@jbignes5
I reality this is not the place to discuss such issues.Let's just stick to the main points and we can always discuss about other things on another thread, when we have more time. lol
@all
About power to run the heating elements, anyone want to take a similar type and run it at 120v or 220v, you will see  how much energy is required, in parallel or in series does not matter, power is power and TK is obviously producing enough of it to do the job during 4.5 hours. I don't think there are any tricks. As for connecting this to the house mains, that is a secondary issue and not even important right now, and actually a great problem to solve when the time comes.
For the TK coil, I did a quick turns count because I would like to make one as close to his as possible.
What I have found is the following...
1st and 2nd layers are 64 turns each.
3rd and 4th layers are 32 turns each.
5th and 6th layers are 16 turns each.
Wire is either 12 or 14 AWG.
I will build it with 14 AWG multistrand (not litz) wire.
wattsup
Zeitmaschine
Quote from: wattsup on August 18, 2012, 11:48:52 AM
About the logical part, that is my middle name.
Some more logic of mine: In the 100KW presentation there is no spark gap, not even an electronic one. If there would have been one and the current in those huge coils would have been driven by high voltage in combination with high frequency the whole environment would have been massively polluted with electromagnetic waves, disturbing all kinds of electronics nearby.
During my experiments with a spark gap and a little coil (size to fit in one hand) my keyboard and my computer mouse went crazy just three meters away. Not to mention the noise in the radio next room.
Hence my best guess is, all prominent displayed TK coils do nothing at all. They are just there to mystify the observers.
The point is, why should investors invest in a device that obviously pollutes the environment with electromagnetic waves, except the investors know that the coils (and sparks) are there for decoration purpose only?
8)
Hoppy
Quote from: wattsup on August 18, 2012, 02:59:20 PM
wattsup
Can we be absolutely sure that it did run for 4.5hrs? Who witnessed this - the investors, the testers (who clearly did not test it thoroughly) or are we accepting TK's word for it?
Hoppy
