0 Members and 85 Guests are viewing this topic.
wattsup
@Zeitmaschine
Then why did they got to all the trouble of making metal boxes on which the large coils were standing on? No one does anything for nothing my friend. Everything has a purpose. Count how many coil towers he used in the demo, then put them all together to output, each tower, in its smaller way was producing a part of the total output. Each tower is an independent functional unit. Each tower can have a spark, not one huge spark for all towers.
So, otherwise, tell me how you can plan to produce a make/break that will last more then five minutes in such an environment?
I know very well about the spark effects on keyboards, etc. I live with that every day. Does a furnace ignitor wreck havoc on home devices? Hmmmmm. Do your car spark plugs wreck havoc with your car radio. Everything has a solution and a time to apply that solution so I fail to see the logic of saying the Tent demo had no spark gaps.
Also those havoc effects are very frequency dependent. Change the frequency and the problem is solved. The right frequency to run the TK devices may be a frequency that does not play havoc with anything.
I would say the contrary. Given the size of those towers, the spark gap needed to be much stronger and this is why they put those metal boxes in place, otherwise that  Tent demo would have sounded like a firing squad. Again, why else would you go to all the trouble of sourcing for those boxes or having them specially made, when a simple table would have been all that is required to keep them off the ground. Now if you are hiding capacitors in those boxes, then again, why use metal boxes?
wattsup
Zeitmaschine
Quote from: wattsup on August 18, 2012, 03:31:33 PM
Except Kapanadze. See both aquarium boxes filled with garbage electronics.
As soon as I connect a huge unshielded coil to the spark plugs.
To shield the frequencies that the device uses in order to prevent unauthorized measurements. If the frequencies would run through the huge coils everyone could measure them unnoticed at a distance. And as we know, Kapanadze freaks out if someone wants to measure the frequencies of his device.
:D
MasterPlaster
Quote from: jbignes5 on August 18, 2012, 11:19:01 AM
Well it also seems that there is two different kinds of induction. One is of the heavy current type or magnetic induction and the other is of the high voltage kind or electric field(static) induction. Both use the same kind of rules but they seem to be of opposite character. Both are also related to each other at the zero line. Meaning they are tied to the zero point but radiate oppositely (90 degrees). etc etc.
Here is something similar:
[size=125%]Motional Electric Field Associated with Moving Charges
http://archive.org/download/MotionalElectricFieldAssociatedWithMovingCharges/motional-electric-fields-kyle-klicker-tbc.pdf
cheappower2012
Zeitmaschine
I agree with the you ,the sparks are to fake out the investors,along with a lot of other things.
Wattsup
,in the time you were in the tpu thread didn't you learn anything about deception,sm can fake out anyone,make fools of anyone.
TK is on the same level.The amount of power this device generates to waste 100 watts on a spark show is nothing,TK is very paranoid that someone will figure out hes device,the same as sm was, so he hides it under a lightning show,sm hid it under its a tesla invention.Sm faked out the original members of the tpu thread of which you were one,and I also was one,he only faked me out in the beginning,he still fakes out other original members to this day nothing has changed and they still don't listen,I gave up on them,a long time ago.
I do agree with your assessment of the patients there useless unfortunately.
The best shot at solving TK's secret is the transformer.
wattsup
@cheappower2012
The only relationship I can see between SM and TK is they used the same cameraman for TKs last video. Really, you cannot compare them. SM was a loner. TK has his clan. SM will die with his secrets. TK will pass them on to his clan. SM loved boys. TK, hope not. lol
Listen, there are many views but regardless, all has to be tried and guys will try them all. If you remove the TK coil and the spark gap, you are left with nothing so we may as well pack up the lab and move to Timbuckto (because Beverly Hills is taken). lol
My only last question on that last video is this.
The TK coil is blue wire. We see a blue wire soldered to the triple transformer. Is that wire going to the TK coil? And if yes, it seems to be a single strand and not a multi-strand. If that is the case then this is definitely a game changer if the TK coil is wound with a single stand, probably high voltage wire. I already have my 14 awg multi-strand but will wait to see if anyone has anything or if there is another photo available that can clarify this very important question.
wattsup
