0 Members and 588 Guests are viewing this topic.
jbignes5
 Hello... Anyone home?  Hasn't  anyone thought to put this in the same light as Mary Ainsley's heater circuit? It is the very same concept except at a much larger configuration. This stuff is much different then normal electricity. It works way more efficiently then regular electricity and to boot you don't need to convert it because that is a part of the of the method here. The heating elements are configured much the same as a coil if I remember that Turkey video right. Remember that this stuff energizes different metals with different effects and the Turkey video is done on a much different scale and configuration then the other videos as well.
The Turkey video is done in a Tesla style but the other are not done in the same method. Two distinctly different circuits with two different configurations. Don't get them confused. If you were attempting to discover what he has done among all the different videos, Gosh no wonder you guys are confused. Although the basic concept is the same the fields are much different. The 2004 video in the back yard has the radiator element (heavy copper coil) closely tied to the load coil. The Turkey video is a broad field implementation with a Tesla coil radiator near but not surrounding the drive coils. No wonder why you guys are waffling back and forth about the method.
I tell you what pick one video and lets figure that out and not refer to many many different videos. It's much less confusing.
jbignes5
Quote from: MasterPlaster on August 18, 2012, 05:11:42 PM
Here is something similar:
[size=125%]Motional Electric Field Associated with Moving Charges
http://archive.org/download/MotionalElectricFieldAssociatedWithMovingCharges/motional-electric-fields-kyle-klicker-tbc.pdf
There it is. I knew it was somewhere but my memory is becoming rather vague of late. I'm not getting better and my back is getting worse. Pain has a way of distracting you from things like a great memory I once had.
This is a prime example of the theory of Hooper. Somewhere in there we need to look and see if what I had proposed is correct. If there are errors in the concept of magnetism we should be able to figure this out from what was observed by Hooper and Kicker. Leedskalnin should be looked at as well to see if the magnetism is something more internal and then converts to the electric field on the outside of matter. Or some process like that.
Free.Energy
Quote from: cheappower2012 on August 18, 2012, 05:41:48 PM
Zeitmaschine
I agree with the you ,the sparks are to fake out the investors,along with a lot of other things.
Wattsup
,in the time you were in the tpu thread didn't you learn anything about deception,sm can fake out anyone,make fools of anyone.
TK is on the same level.The amount of power this device generates to waste 100 watts on a spark show is nothing,TK is very paranoid that someone will figure out hes device,the same as sm was, so he hides it under a lightning show,sm hid it under its a tesla invention.Sm faked out the original members of the tpu thread of which you were one,and I also was one,he only faked me out in the beginning,he still fakes out other original members to this day nothing has changed and they still don't listen,I gave up on them,a long time ago.
I do agree with your assessment of the patients there useless unfortunately.
The best shot at solving TK's secret is the transformer.
I disagree that the spark gap is to fake out investors.  If you have experienced the flashless discharge then you know very well that a large amount of energy is there and if you allow it to rise it will find it own path and everything is fair game.  The spark gap shows then process is working and the excess is dumped to ground.
Remember what they all agreed on: a shortage of energy will not be the problem, quite the opposite
To be honest, is really doesn't matter how TK is actually configuring his system.  The principles are the same.  You send a pulse to a coil with a breaking configuration.  The energy is manifest at right angles to the coil.  You use to this by magnetic induction or electrostatic induction.
The transformer is irrelevant.
TK might as well have painted smiley faces and flowers on it, along with his middle finger.  His secret is safely hidden in the box.
As for SM, he is still around.  His last incarnation was as "TheBuzz", harbinger  of "cavitation".  Once you call him out, he cowers like the whelp that he is.
Apparently, v8Karlo's device does not exhibit the charging effect, o it is therefore inadequate and nothing more that a curiosity.
sparks
  Does anybody see any value in transforming 1volt for 1 microsecond to 30,000 volts for 1 microsecond?  Doesn't amperage (work done) = voltage/resistance.   Why do we increase the impedance and resistance of a stepup transformer secondary?  Wouldn't it be wise to lower the impedance and resistance of the secondary therefore getting current gains in the output circuits that are directly proportional to voltage increase.  Why was Tesla so fascinated with highvoltage (impulse) electricity?  Why did Westinghouse continue to make saturable core transformers when Tesla showed him his air core transformers?  Does a spark gap have to short to transfer power to the secondary or can it be used as a variable capacitor to couple the primary to the secondary?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
jbignes5
Quote from: Zeitmaschine on August 18, 2012, 03:05:56 PM
Some more logic of mine: In the 100KW presentation there is no spark gap, not even an electronic one. If there would have been one and the current in those huge coils would have been driven by high voltage in combination with high frequency the whole environment would have been massively polluted with electromagnetic waves, disturbing all kinds of electronics nearby.
During my experiments with a spark gap and a little coil (size to fit in one hand) my keyboard and my computer mouse went crazy just three meters away. Not to mention the noise in the radio next room.
Hence my best guess is, all prominent displayed TK coils do nothing at all. They are just there to mystify the observers.
The point is, why should investors invest in a device that obviously pollutes the environment with electromagnetic waves, except the investors know that the coils (and sparks) are there for decoration purpose only?
8)
Did you miss the huge Tesla coil behind the towers twords the right of the platform. There was a huge Tesla coil there Complete with it's circuitry. Now I'm gonna have to re-watch the video yet again and pull pictures of the whole thing.
Oh wait Stivep might have them. Stivep you still around?
Found it. Do you see the coil with wooden dowels?? Thats a plain old Tesla coil. The one closest to the camera? Oh and the caps are right between the metal box and the left most coil. This is actually just like Tesla's experiment with all the coils within his Colorado experiment. Except these are outside of the primary ring which in that case was a whopping 90 or so feet across. I'll see if I can get that picture as well.
Ok added the two pictures I could find. Sorry about the quality but it's the best I can do at the moment. The last is so small it's useless really but it gives you a taste of what I meant.
