0 Members and 463 Guests are viewing this topic.
Omnibus
Maybe this also deserves a commentary:
http://www.faqs.org/patents/app/20080297134
Is this a patent or just a patent application? Couldn't see the schematics.
hartiberlin
Here is still one of the first videos
this youtube user
nextenergyru
had put up,
who has closed now his account.
Here you can still see the inner structure of his coil.
There are not yet ferrite toroidal cores as I can see.
I wonder, where the one black wire goes to, which
goes to one one bulb pole ?
Also, what is this thing that lays on the floor
and is quadratic and has this blue tape on ?
http://www.youtube.com/watch?v=18oThcI4VnE
Regards, Stefan.
gyulasun
Quote from: Omnibus on April 03, 2010, 11:44:14 PM
It is an application: US 20080297134
copy and paste the number into this link http://www.pat2pdf.org/ to get the full text and figures.
xenomorphlabs
Quote from: hartiberlin on April 03, 2010, 07:24:50 PM
Hi xenomorphlabs,
many thanks for posting this new circuit diagramm,
yes, that looks more like the circuit from the SR193 video.
Where did you exactly find this circuit ?
Please always post for reference also the source URL.
Many thanks.
Well, so the diagram says, that it is a standard 12 to 220 Volts inverter with an additional
High Voltage coil added, that is powered by a spark gap ?
I remember Aaron Muraki from Energetic forum has done a video,
where he showed a bigger sparking when adding something simular.
But I don´t find his youtube video right now...
Okay, let the ideas come in, how this circuit works.
Many thanks.
Regards, Stefan.
Stefan,
the circuit is from http://www.001-lab.com.
The circuit you posted was posted there as well.
There is something missing in it i believe, because
the transistors are not being fed with any (sinusoid) signal that would make them drive the transformer with AC ?!
Or have i overlooked something?
To have the spark gap in perfect sync with the inverter, i think it is best to use the same drive signal for the output transformer and the HV transformer to feed the spark gap.
It is being hypothesized that the spark gap impulse creates a wide range
of frequencies that will include the ferromagnetic resonance frequency.
The ferrite is then oscillating with it´s own resonance frequency and a superimposed 50 Hz frequency maybe, resulting in a higher output.
hartiberlin
Quote from: gyulasun on April 04, 2010, 06:13:04 PM
Here is the full PDF file with pics:
http://v3.espacenet.com/espacenetDocument.pdf?flavour=trueFull&locale=en_EP&FT=D&date=20081204&CC=US&NR=2008297134A1&KC=A1&popup=true
You must first fill in the graphic capture code into the form,
then the download will start.
