0 Members and 554 Guests are viewing this topic.
a.king21
Quote from: sparks on August 19, 2012, 02:24:45 PM
Jbigness these are all props for TKS disinformation campaign.  Don't you understand what lengths TK will go to to lead us down the garden path.  I mean these are cheap to build.  Absolutely no engineering needed there.  Tk obviously has some uranium stashed in his blackbox.  In one of the videos we have a guy running around with a video camera tracing a ground wire.  He pans the camera into a room where there are 3 high voltage devices with mushroom dome aluminum capacitors that look by goodness like 3 telsa transformers.  Suspended above these transformers is a huge copper or brass net.  A properly functioning teslatransformer gives off zero rf so why the huge massive free electron scource hanging above the three tesla transformers which appear to suffer from coronal discharges just like a little sg. Could this net be a virtual ground or is the net an extension of a real ground.  If someone recognises the video I mention above and has it would you please post it.  I can't believe anybody is even looking at patent information or anything else when TK comes straight out in his first video and credits Tesla for his rediscovery.
Which Tesla re-discovery would that be exactly? Please tell me as you seem to know.
Bernhard
@a.king21 - Thanks!
Where there is this conclusion from the small coil? ๏̯͡๏
sparks
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
anandml
Quote from: Zeitmaschine on August 19, 2012, 06:30:14 AM
If the sine wave is a 50Hz wave then the use of an iron core is recommended in the coil next to it.
A Tesla coil what for? To mislead people to think this free energy generator has anything to do with a classic Tesla (spark) setup? And what's the black huge cylinder in the background for? Is this also a coil or is this - at least this - decoration only?
BTW: The patent WO 2008/103130 states »There is not encountered any application in prior art related with the invention improved with this invention.« Therefore this cannot be a Tesla related invention as TK had said in the green box video. Except Tesla had intentionally not patented his invention.
But isn't a transformer a coil also?
Free energy from nothing, isn't this exactly that what we are all looking for? ::)
Impossible or not impossible? This is here the question. If the spark is not needed, then also the coil is not needed, then also the high voltage is not needed. Neither high voltage nor a spark gap is mentioned in one of the two TK patents. Hence what's left? Maybe an energy transformer?
Create continuous heavy Back EMF by means of high frequency in the iron core of an ordinary transformer and mix it with the 50Hz frequency created by an 220V inverter. The outcome could be free energy - or a burned-out inverter.
If someone could try this and tell us the results please. :)
THANKS....for your valuable information... I read all ur posts so i know u are on the right track.. your layout diagram help me to clear some doubts once again thank you very much
One request pls mention much more details about Main board and tell me how to create high frequency. you have 2 inverters????
