0 Members and 58 Guests are viewing this topic.
Bernhard
Quote from: Muromets on August 20, 2012, 12:02:07 AM
Hi to all!
The transistor is alone?
@Muromets
Yes the transistor on a radiator one, instead of the second it is empty
Hoppy
Ref post 12723 Pic3. Where is the lead under the chair near the door going to? Can someone with a good graphics application please enhance / blow this area up to get more detail.
wattsup
@Bernhard
While you were posting this....
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg332929/#msg332929
I had found it as well coming off the center coil and going out to the right to ground. The one with the ??? I think is just a reflection from the ground.
I have been looking and looking for the last missing wire off the center coil.
The coily coil starts from the two transformer point. One goes to the left and the other goes to the right. I don't think they are then just meeting in the center. There should be a center tap somewhere that connects the outer coil to the center coil.
This would provide 6 or 7 turns per coily coil half and equal the 6-7 turns of the Green Box 6fat coil times two. If this connection can be found, this would mean the center coil is being used as a path to enable the complete path of both halves of the coily coil to be pulsed since both ground would land inside the center coil. This would also equate to the Green Box TK coil being wound in the same way as in the Aquarium 2 TK coil, but there they would an extra coil to the left of the 6fat coil to act as the center coil for the 6fat. Starting to make great sense but that one wire connection is missing to make this complete. If you ever find it, please post it.
There is no fighting. Only sharing of opinions. The Aquarium2 spark gap wires lead inside the black section so there is no way to know how they are related when coming out to the triple transformer.
wattsup
Jon_sparky
Quote from: anandml on August 19, 2012, 10:41:34 AM
IMPORTANT NOTE
After watching TK 2004 video again and again i can able to understand only one thing he used spark gap for decoration purpose only. TKs spark gap is 100% fake. With out spark gap the device will run continuously. If there is no need of  spark gap what is the use of transformer , rectifier, transistor etc. Inside tin can he placed fly back transformer ok.. remaining place he utilized for hiding capacitor or any other items. IF anybody have idea about that? ???
In patent he didn't mentioned high voltage because there is no need of  spark gap.... Why he use diode???
Due to wire stretching fly back transformer ground connection is disconnected So no spark present after connecting the battery charger. pls watch video again and again
Some Quest-ions ??
How would anyone compare the Aquarium coil config with TK´s 2004 coil?
Is the top winding on the Aquarian substituting for the copper primary on the 2004?
Why bifilar or multilayer? (if stupid question please be patient, I want to solve the mystery too)
What is the output of the transformer anyone?
Big question - Why dig a hole and bury a car radiator if not the energy source?
But that beach demo - there is no burial was there?
Has anyone considered a triple plate earthed capacitor method, which could easily fit in the tin-can. This is more commonly known as an Avramenko plug but basically has a generator coil connected to one plate, the other two plates are earthed so the cap charge is then set by the earth not by the circuit?
Free.Energy
In the TK 2004 device, there is a transformer shown that converts power from an outlet or inverter and has a plug connected directly to it.  TK didn't bother to hide it.  What is the black object on the bed that has all the wires for the lamps?  What is in the round can next to the coil?  The square an is also in the green bx video and is connected between the output and the inverter, so some way to condition power for inverter in place of battery.  The can lid has holes and may get hot.
The 2012 aquarium device has all the bells and whistles in clear view because they are fake.   What is in the black box?
