0 Members and 104 Guests are viewing this topic.
a.king21
Quote from: dllabarre on August 21, 2012, 10:15:39 AM
Finally you guys are coming around to what I've posted and shown pictures of, several times over the past year.
"The secret is what's hidden in each device.  There are 2 objects that appear to be coils hidden in Green Box, Wesley's demo (plastic box) and bottom view of Aquarium 1 device."
If these are hidden coils - The question remains: how are these 2 coils wound and how are they connected to each other?
OR are they 2 hidden capacitors?
DonL
We already know how they are connected - I've posted the circuit already, or you could try v8karlo's version, which is  simpler.
What we didn't know was the principle of energy gain. I suspect a scalar inductive capacitance effect.  A cross between v8karlo's circuit and Tesla's pancake coil windings. Anyway we're getting close.
I recently asked Tariel the following question (before he crapped on us). Can your device be micro miniaturised to fit into a CFL lightbulb? He thought for a few moments and then replied "No because you may have seen that I use bifilar windings."
I knew then that he did not have a clue about modern micro-miniaturisation techniques. So it makes me even more frustrated to know that we are dealing with a late 19th century technology here.
wattsup
@Bernhard
You can fit a nice flyback transformer in that can as well. I don't think you will find a HV toroid like that one you are showing.
Also did you happen to see my previous post.
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg332981/#msg332981
We need to find the other wire from the center coil. lololololololololol
I know it is not easy. Either that or we have to extrapolate some variables.
@all
But there is so much more we know. More cards on the table to see if TK is playing a bluff or if he holds a royal flush.
TK built this device in sections.
Section 1
9vdc Battery start-up plus two on/off switches.
Section 2
Ground - TK coil - Load - Transformer 1/3 HV Positive only - HV negative NOT USED
Section 3
Ground - Center Coil - Coily Coil (possibly center tapped) - Transformers 2/3 an 3/3 Positives with negatives to same Ground.
Section 4
Ground - Spark Gap - Unknown (but there seems to be a HV transformer behind the black wall.
I found a neat image of someone seeming to be inside the box, but is it someone thinking out of box instead? hehehe
Also I am putting revised changes to the connect diagram.
wattsup
27Bubba
"Why does he need to switch on a start capacitor when he has a large battery on the bench?"
The switch could be leftover from previous design/experiment. If I remember correctly while back Wesley mentioned the switch wasn't used..
sparks
    I keep saying this is Tesla tech but nobody is looking for the transmitter.    I think I found it in the motor running in the warehouse.   SM's tpu same thing.  Again we have someone who studied Tesla and everyone is looking for batteries hidden in the device and not looking for the transmitter.   Mr. Marks in some way tried to validate his experiments by placing a television set near his "this is not a free energy device.  This will replace all battery systems"  A television set will not be effected by a Tesla wave because an electro-magnetic wave varies in intensity over a given amount of time whereas a Tesla wave varies time while remaining constant in space.  Sounds weird but time is not a constant.  Regardless wireless transmission of power is cool and on a global scale would bring the human family together.  In latter years after his magnifying transmitter got pulled he still openly stated he had created an energy sink.  If you can take heat and turn it into coherent light then you "cool" things down.  The heat will just keep on flowing into your system and leaving as coherent light.  For example instead of running a motor and fan which actually adds heat to the formulae you power a laser which beams that shit straight out into space.  How long before global warming converts into global communications and wireless transmission of power?  We as a soceity and moreover the established scientific community has to move beyond the archaic laws of thermal dynamics that was calculated by engineers trying to figure out how much coal a train needed or how much chemical energy a certain state of elements has.  It's all electrical.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Jon_sparky
Quote from: Shokac on August 20, 2012, 03:21:04 PM
Look this pictures!
This is not 12V rectifier. This is 2000V rectifier with D171 rusian diode
Diode D171
Super detective work Shokac !
Can we say what the voltage is output from the transformer?
So the 220V AC 50Hz from the Inverter is rectified to pulse DC.
After device is started, Inverter+Transformer not needed?
