0 Members and 516 Guests are viewing this topic.
starcruiser
Well I DL'd the Video Shokac provided a link to but Unfortunately I do not speak Russian, can some one assist in a summary translation? I was looking to identify the item that looks to be a capacitor that is in the ground path (so it looks) going back to the MosFET which looks to be driving the aircore coil
I see the following;
Aircore Coil  2 1/4 layers (approx) looks to be 112T, the second coil on that form at the end looks to be about 16T
AC capacitor across the coil (LC tank)
Tank being fed by the MosFET with a 9amp driver chip (guess since there are not other components showing and it looks similar to one of the units I have in my TC driver) I included the schematic from my TC driver for an example
Some of the side components (Left side) looks to be a power supply and signal source (555 timer with duty and freq adjustability?)
that transformer on the left looks to be used as a choke since one side is not connected.
so it looks to be fairly simple in design over all, just need to understand the funky capacitor which looks to have 3 connections? or is it just a filter cap? dunno.
Is that  fan under the MosFET heatsink?
Regards,
Carl
poynt99
Quote from: a.king21 on August 21, 2012, 03:28:02 PM
We still have not identified this wire.
It appears to be high tension wire; possibly from a spark plug harness. TK used the same wire on the green box device.
starcruiser
The wire looks to be some sort of standard stranded house wire, perhaps 12 gauge or maybe 14 gauge
Regards,
Carl
T-1000
Quote from: starcruiser on August 21, 2012, 05:19:45 PM
It is quite simple :) The coil is wound on selenoid with 2 layers of wire and attached to 0,1mF 1000V capacitor in series. Then he got 19V notebook power supply, TTL (555) generator, mosfet driver and mosfet. The plus of power supply goes into coil over current transformer then into mosfet from the coil. The minus of power supply goes straight into mosfet. What guy claimed about power consumption is this: those coils are working on diffferent frequencies and sometimes the circuit draws more power when there are sparks in current transformer or short circucit and sometimes it is not when it is tuned.
Because there are no measurements you may repeat the experiment yourself if interested then share video with everything.
Cheers!
starcruiser
@T-1000, perhaps simple for you since you understand Russian ;)
So the radial capacitor near the edge of table has the PSU across it is what you are saying correct?
I would think that the filter cap might need to be adjusted (uF value) to avoid a conflicting resonance, JMO.
This could be driven using a commercial TC driver then or similar, this avoids the hassle of building from scratch the driver components, I think I might have the capacitors on hand and I can wind my Aircore transformer since I have the supplies on hand.
At least I have an isolation xformer (variable too) that I can use to limit the drive voltage and current is limited to 4 amps max. I might give this a try this weekend
Regards,
Carl
