0 Members and 65 Guests are viewing this topic.
frankidel
Quote from: a.king21 on August 20, 2012, 07:42:00 PM
Close up of the blue wire piece on the table. It's not often we get a chance like this.
To the sparkies (electricians) amongst us. What kind of wire is this?
What kind of insulation is it?
What is it used for?
BTW thanks to all for your excellent detective work. It helps a lot.
i would guess some kind of gto cable for spark plug, notice the large insulation....
Zeitmaschine
Quote from: anandml on August 19, 2012, 11:04:37 PM
THANKS....for your valuable information... I read all ur posts so i know u are on the right track.. your layout diagram help me to clear some doubts once again thank you very much
One request pls mention much more details about Main board and tell me how to create high frequency. you have 2 inverters????
Kapanadze patent shows apparently two inverters. But one is for start-up only.
Now how to create high frequency on the main board? cosmoLV knows:
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/6120/#msg278542
»Transistor setup are most important with back loop to generator. «
If there is a grain of truth in that statement, what could this mean? Let's say the principle of work is based on Back EMF. Hence a transistor switches on a coil (of a transformer). As soon as the magnetic field of the coil is saturated, there is a back impulse that cuts off the transistor in order to generate the max. possible Back EMF with the min. possible power consumption. Could this be that what TK calls »auto-resonance« or »keep resonance«? Could this be the mysterious »Phase stabilizer« (12) in the patent?
So the duty cycle of the high frequency which creates the Back EMF is not 1:1 (or something else set to a fixed value) but automatically adjusted to the needs of the coil at a given time. (?)
Just thinking out loud ... :P
Jack Noskills
Quote from: a.king21 on August 21, 2012, 10:46:31 AM
We already know how they are connected - I've posted the circuit already, or you could try v8karlo's version, which is  simpler.
What we didn't know was the principle of energy gain. I suspect a scalar inductive capacitance effect.  A cross between v8karlo's circuit and Tesla's pancake coil windings. Anyway we're getting close.
I recently asked Tariel the following question (before he crapped on us). Can your device be micro miniaturised to fit into a CFL lightbulb? He thought for a few moments and then replied "No because you may have seen that I use bifilar windings."
I knew then that he did not have a clue about modern micro-miniaturisation techniques. So it makes me even more frustrated to know that we are dealing with a late 19th century technology here.
What does bifilar windings do ? They add capacitance between windings. What does this do ? It adds capacitive reactance which balances inductive reactance. Get it right and you got resonance condition. What else does it do ? It creates displacement current which you can use. TK is using capacitive induction, you should check v8karlo's circuit or my version of it. TK has figured out a way how to take the power circulating in the source without affecting it. This is a must requirement for any OU system. I have found it, and so has v8karlo. This should be starting point because it is something to build on, it makes no sense for any more quesswork. If you don't know the principle it is a waste of time quessing what electric components he is using or how they are connected. As most of them are fake. We can babble til the end of time and get no result. We need more experiments and sharing.
forest
Quote from: Jack Noskills on August 22, 2012, 01:05:38 AM
100% agree.
semenihin-77
My version that uses ferroelectric Kapanadze to communicate with earth. Tesla also did so in their coils.
White tube-ferroelectric ceramics. And that makes ferroelectric I showed in the video.
