0 Members and 77 Guests are viewing this topic.
Hoppy
I suggest that TK used a braided metal hose similar to that shown in this link: http://www.techflex.com/prod_MBN.asp
The black lead (probably a mains cable) shown in the attached photo could have been stripped-back and the conductors pushed through the hose at a point low down out of range of close camera shots. The conductors could then have been pulled out of the hose and terminated to other cables inside aquarium and insulated with tape as shown in other photos in this thread.
captainkt
@Hoppy, what you are suggesting is an absolute insult to the people that went out to look at this generator, it was held free of all but the earth and this was also looked at closely. Kapanadze would not put his reputation on the line for a cheap trick. Look at generator on small Island to see no mains used.
Free.Energy
Quote from: Jack Noskills on August 22, 2012, 01:05:38 AM
What does bifilar windings do ? They add capacitance between windings. What does this do ? It adds capacitive reactance which balances inductive reactance. Get it right and you got resonance condition. What else does it do ? It creates displacement current which you can use. TK is using capacitive induction, you should check v8karlo's circuit or my version of it. TK has figured out a way how to take the power circulating in the source without affecting it. This is a must requirement for any OU system. I have found it, and so has v8karlo. This should be starting point because it is something to build on, it makes no sense for any more quesswork. If you don't know the principle it is a waste of time quessing what electric components he is using or how they are connected. As most of them are fake. We can babble til the end of time and get no result. We need more experiments and sharing.
All of which does not add more energy than you put into it in the first place, so how is it a requirement for an OU system?
Qwert
Quote from: Free.Energy on August 22, 2012, 09:23:17 AM
This is proper knowledge to build OU device.
s-q-s-a (stupid question, stupid answer).
Shokac
This is taken from
http://www.free-energy-info.co.uk/Chapt3.html
Question: Why are you so sure that this is a design of Nikola Tesla's?
Answer: Because I worked from his invention - his design.  I discovered how to get automatic resonance between the primary and secondary windings.  The most important thing is to achieve resonance. Melnichenko came close to solving this problem.  The government of Georgia refuses to take this invention seriously.
Look Melninchenko setup:
http://www.youtube.com/watch?v=p_EjFWpHiLY&NR=1&feature=endscreen
Kapanadze secret is in the starting transformer NO IN THE BIG SOLENOID.
