0 Members and 57 Guests are viewing this topic.
forest
Quote from: Shokac on August 22, 2012, 10:10:15 AM
This is taken from
http://www.free-energy-info.co.uk/Chapt3.html
Question: Why are you so sure that this is a design of Nikola Tesla's?
Answer: Because I worked from his invention - his design.  I discovered how to get automatic resonance between the primary and secondary windings.  The most important thing is to achieve resonance. Melnichenko came close to solving this problem.  The government of Georgia refuses to take this invention seriously.
Look Melninchenko setup:
http://www.youtube.com/watch?v=p_EjFWpHiLY&NR=1&feature=endscreen
Kapanadze secret is in the starting transformer NO IN THE BIG SOLENOID.
I don't see any modification to transformer. Forget about it!
captainkt
@Forest, Transformer has bolt together type laminations so easy to mod not like a MOT type that is welded together.
Keith
forest
Quote from: captainkt on August 22, 2012, 11:20:24 AM
Keith
Ok, what modification you see ? Don't you think that layers should be enclosed by different colour tape ? I'm sure Tariel had no such exact commercial paper used there... Again ... I don't see any modification because there is no such done!
starcruiser
shokac, I agree, it seems that the line reactor transformer is the key here
Check this out  http://www.youtube.com/watch?v=wQLeEe8HtbQ&feature=related
look familiar? I think this is also a similar solution to the SM TPU as well albeit hand made instead. Use the center coils to create the LC tank and use perhaps a biasing DC voltage to increase reluctance in the center leg, then tap the output using the outer coils or perhaps using a DC bias on the outer legs to increase performance.
Thoughts please?
Edit:
After eating lunch and putting some thought into this, perhaps the better idea is to use the line reactor (3 phase xformer) to tap the VARS from an LC tank circuit (Aircore coil/cap combo ?) and convert from VARS to usable VA.
Beyond that Idea I was thinking that the inverter he uses is the source for the center coil in the Line Reactor and the additional coils would be control (biasing) coils perhaps. Ideas here, perhaps the OP that has the actual line reactor TK had in his fish tank can try a few of these ideas.
Regards,
Carl
Shokac
Quote from: forest on August 22, 2012, 11:11:13 AM
forest, we all play with high voltage and after 890 page nothing hapend with this staff
I try with diferent look to this device!
