0 Members and 51 Guests are viewing this topic.
magneto_DC
Quote from: forest on August 22, 2012, 02:16:30 AM
is using capacitive induction, you should check v8karlo's circuit or my version of it. TK has figured out  ............  for any OU system. I have found it, and so has v8karlo. This should be starting point because it is  ....
Hi forest,
did you latley modfy your post? No propblem!
But where could  I find your version of capacitive induction? I gone your postings back to May 2012 but did not find.
I would appreciate much you give (again) the link to your version.
Thanks a lot
magneto
forest
Quote from: magneto_DC on August 22, 2012, 02:03:09 PM
Hi forest,
Thanks a lot
magneto
That was not me, you messed with comments. Check again.
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg333215/#msg333215
slapper
Quote from: starcruiser on August 22, 2012, 11:50:21 AM
[snip] and use perhaps a biasing DC voltage to increase reluctance in the center leg, then tap the output using the outer coils or perhaps using a DC bias on the outer legs to increase performance.
Thoughts please?[/snip]
the dc bias is used to adjust the magnetic field for the target material's (core)  larmor frequency. if, for example, a crystal oscillator is used for the high frequency 90 degree pulse source you can adjust the dc current in the solenoid coil to get the target material's larmor frequency to match the crystal frequency. the higher the magnetic field the target material is exposed to the higher larmor frequency required.
take care.
nap
ref: http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg332757/#msg332757
we are not alone :)
Shokac
Try this setup and look Amps with load connect, and without load...
My measurment: without load 2.30A on 220V side, with connect load 2.77A on 220V side, and 0.96A on load side.  :) ;)
x_name41
a.king21, I want to ask you output blue wire from green transformer as given to the scheme is it?, because you were there.
