0 Members and 101 Guests are viewing this topic.
Jon_sparky
Spot the Cap + wiring behind the (rectifier) diodes,
any idea of item top left - heat sink for transistor ?
frankidel
Quote from: Jack Noskills on August 22, 2012, 01:05:38 AM
What does bifilar windings do ? They add capacitance between windings. What does this do ? It adds capacitive reactance which balances inductive reactance. Get it right and you got resonance condition. What else does it do ? It creates displacement current which you can use. TK is using capacitive induction, you should check v8karlo's circuit or my version of it. TK has figured out a way how to take the power circulating in the source without affecting it. This is a must requirement for any OU system. I have found it, and so has v8karlo. This should be starting point because it is something to build on, it makes no sense for any more quesswork. If you don't know the principle it is a waste of time quessing what electric components he is using or how they are connected. As most of them are fake. We can babble til the end of time and get no result. We need more experiments and sharing.
Hi jacknoskills, i really would like to replicate your circuit and experiment with it, could you repost it please.
Magluvin
Quote from: Shokac on August 22, 2012, 04:31:42 PM
Try this setup and look Amps with load connect, and without load...
My measurment: without load 2.30A on 220V side, with connect load 2.77A on 220V side, and 0.96A on load side.  :) ;)
Hey Sho
.96A on the output seems to be short of 2.3A or even 2.7A at the input. Are you getting more voltage on the output? Thus  :) ;) W output compared to input?  ;]
Mags
dole
It must be simple, TK is pulsing primary coil with HF 220 VDC from Cap, causing HV in primary circuit,
charging secondary circuit of capacitor/coil by HV diodes end discharging partly back to primary in phase at lower harmonic magnifying source. Everything is done by utilization of EMF and CEMF.
Ground is node of two circuits in phase of primary higher harmonic and discharging (50 Hz) lower harmonic,
SG is voltage protection to ground and what I believe (did not test jet ) causing out of phase.
Reasons Way Malicenko was close is two circuits but what I believe they are not in feedback phase.
I made some experiments what seams promising as only solution in my opinion.
Important behaviour is harmonic oscillation of two frequency in phase.
I remember, destructive oscillation is not caused by action but rather by reaction at natural resonant frequency.
There is much more to say but I need to solve many practical problems before final prototype and completing theory.
Here is mine, but not important in my opinion, any good conductor will perform the work
d.
