0 Members and 474 Guests are viewing this topic.
a.king21
Quote from: x_name41 on August 22, 2012, 04:39:37 PM
a.king21, I want to ask you output blue wire from green transformer as given to the scheme is it?, because you were there.
I was not there, but I am in regular contact of two members of our team who were there. They cannot remember much about the wiring. I am doing the best with the high resolution photos we have.
Zeitmaschine
Kapanadze's little mistake (second one):
Questioned about where his resonance is, he says »Here, the resonance between primary and secondary windings« and points at the green box first, then he thinks twice and points at the coil outside the green box. Then he says »The resonator is inside«.
So what is inside the box? A 50Hz transformer? That means the prominent displayed coil outside the green box has nothing to do with resonance, this is only showcase. It has the same effect on the lamps like an extension cord on a cable spool, namely none. It is the transformer »resonator« inside which is important. But he can't admit this of course.
Thus, how to keep resonance between primary and secondary windings of an ordinary 50Hz transformer?
Quote from: forest on August 22, 2012, 11:47:13 AM
I don't see any modification because there is no such done!
What if no modification of the transformer is needed?
Let's assume in the 2004 video the high frequency spark does nothing (and neither do the coils). What's left? A 50Hz transformer (with rectifier) and a high voltage frequency generator in the tin can (for the useless spark).
Kapanadze's little mistake (first one):
But ...
... as in the the 2004 video can be seen (at 20.48), the spark does not fire prior to the start-up of the lamps. What does this mean? a) the high frequency generator has started but high voltage has failed, or b) the high frequency generator itself has failed?
In the latter case the assumption can only be, that the device does not even need high frequency in order to work. And thinking twice myself, I'm not sure, how a 50Hz transformer could make use of a frequency in the realm of 100KHz (as the color of the spark suggests while working).
Quote from: a.king21 on August 14, 2012, 04:33:35 PM
He told me he was terrified to disclose the secret because it could be easily copied. His words were -it's so simple - you'll laugh.
It's time to burst into laughter soon, isn't it?
And now for something completely different (in German, p. 6):
Free Energy for All
»Reactive power« (Blindleistung) gets somehow converted - by means of a »state of resonance« (Resonanzzustand) - to »effective power« (Wirkleistung) according to a Russian company named »Steho«. The image with the bank of lamps in this pdf looks somewhat familiar, doesn't it?
As it seems, time is running out for Kapanadze.  8)
a.king21
Quote from: captainkt on August 22, 2012, 07:03:16 AM
@Hoppy, what you are suggesting is an absolute insult to the people that went out to look at this generator, it was held free of all but the earth and this was also looked at closely. Kapanadze would not put his reputation on the line for a cheap trick. Look at generator on small Island to see no mains used.
I was not going to take his post seriously and neither should anyone else. Yes there is a wire there, just as in your house there are many wires. Mobile phone chargers, battery chargers, electric radios, tvs - need I go on? The device was scrutinised by all present and a video taken. The silver braid was tied in a rough knot to a bronze braid.  Grow up Hoppy. Get a life.
a.king21
Braid: I have some vital information on the braid. When I first ordered the aquarium 2, Kapanadze was in regular contact with one of our team - a Georgian national. Anyway he informed me recently that Kapandze was panicking because he could not get coaxial cable from his regular supplier and feared he would have to go to Turkey to get some. Anyway he eventually found some coax in Georgia.
His device desperately needs about 5 meters at least of braid  between 2 - 5 mm for his device to function.  Without it he cannot build his device.
Secondly, on the day of the demonstration there was a storm and it rained heavily. Kapanadze refused to let the demonstration go ahead saying that it would affect the neighbours' electricity supply. Only when the storm finished was our team allowed to witness the 4 and a half hour demonstration.
What is interesting is that he uses braid for the earth lead. But more importantly is the use of braid inside the device.
The Russian term used sounds like plytionka or pletionka.
Why not use ordinary cable?
This indicates radio frequencies to me. At least high frequency.
Comments from the EE's would be welcome.
Come on guys, we've got him on the run. Let's take his toy away from him.
wattsup
Quote from: starcruiser on August 22, 2012, 11:50:21 AM
After eating lunch and putting some thought into this, perhaps the better idea is to use the line reactor (3 phase xformer) to tap the VARS from an LC tank circuit (Aircore coil/cap combo ?) and convert from VARS to usable VA.
Halleluiah, someone is keeping track. lololol
@all
And so the plot thickens once again. I think I found the missing wire from the HV negative.
See image below. Shows there is a grey wire connected to the HV- and it goes to the #3 terminal of the same coil since you can see it is in front of the #3 wire solder point. I made correction to the circuit diagram also below.
Hehehe.
wattsup
Added:
@stivep
Where are you these days? My wife is leaving next Monday to do again the walk of Compostel (4-5 weeks) so I will have much more time to work on this very soon. hehehe
@all
As a side note, looking at the Green Box video at 13:31 where one switch is on and the fan is running, you can hear the noise of the fan, but when he flicks the second switch, there is a new noise so in this green box is something that is started that makes a noise. Maybe a sound analysis there would be good. Could be a motor or other pulsation method with a known frequency, don't know, but it may be a relevant finding to the internal function.
