0 Members and 126 Guests are viewing this topic.
frankidel
Quote from: a.king21 on August 22, 2012, 08:28:05 PM
Braid: I have some vital information on the braid. When I first ordered the aquarium 2, Kapanadze was in regular contact with one of our team - a Georgian national. Anyway he informed me recently that Kapandze was panicking because he could not get coaxial cable from his regular supplier and feared he would have to go to Turkey to get some. Anyway he eventually found some coax in Georgia.
His device desperately needs about 5 meters at least of braid  between 2 - 5 mm for his device to function.  Without it he cannot build his device.
Secondly, on the day of the demonstration there was a storm and it rained heavily. Kapanadze refused to let the demonstration go ahead saying that it would affect the neighbours' electricity supply. Only when the storm finished was our team allowed to witness the 4 and a half hour demonstration.
What is interesting is that he uses braid for the earth lead. But more importantly is the use of braid inside the device.
The Russian term used sounds like plytionka or pletionka.
Why not use ordinary cable?
This indicates radio frequencies to me. At least high frequency.
Comments from the EE's would be welcome.
Come on guys, we've got him on the run. Let's take his toy away from him.
Hi, i'm not super at this, but if he uses coax cable, could it be that, imagine weight of the copper core is equal to the weight of the braid, i think eric dollard said it is important for keeping resonance,    so maybe he is in resonance with the earth, like stivep said using shumman resonance. so the resonance is establish with the primary and secondary. just a guess
a.king21
Something we're all missing. There's always a  wire through the coil pack.
When Wesley wanted to look into the coil they appeared nervous.
I refuse to believe this is Kapanadze being tidy.
He's an untidy fellow.
Especially his builds.
To the Russian speakers on this forum: please translate this post and put it on the other Russian forum.
Message to Kapanadze:
You  shouldn't have scammed me and my partner.
We're still proceeding with criminal prosecutions against you Tariel.
The police will come  knocking soon. And not just you Tariel, but your Armenian friends - the guy with the moustache and the twins. And hopefully you can say goodbye to your girlfriend Lolita for a few years.
And of course you son, who hosted the event at his house. We cannot leave him out. Especially since he is "known" to the Police. And of course that also implicates your son's wife. She must also be a suspect in the scam.
If you have any sense you will ring soon before it's too late.
ps Please don't make me post your and your Armenian co-conspirators passport details all over the web in my appeal for more victims of your "show an FE device" scam.
We already have two other companies who have been scammed and who have contacted us.
End of message to you Tariel.
Free.Energy
The coaxial cable could be used at a capacitor with a set discharge rate to set the width of a pulse.
The coaxial cable could also be to provide power from hidden cables in the freshly poured concrete.
I see no reason why the device would effect the neighbors power, except that he mentions "rain" which is a dramatic increase in humidity and ground conductivity.  Under this condition, TK device will pull current from neighbors through their ground connections.  So, TK device is real.
Frederic2k1
Quote from: Zeitmaschine on August 22, 2012, 08:00:41 PM
Kapanadze's little mistake (second one):
And now for something completely different (in German, p. 6):
Free Energy for All
»Reactive power« (Blindleistung) gets somehow converted - by means of a »state of resonance« (Resonanzzustand) - to »effective power« (Wirkleistung) according to a Russian company named »Steho«. The image with the bank of lamps in this pdf looks somewhat familiar, doesn't it?
As it seems, time is running out for Kapanadze.  8)
Resosnanz bewirkt immer, dass 'Radient Energy' in den Knoten der stehenden Welle eintritt. Hast du dir mal von bolt das Experiment angeschaut, welches er im Magnacoaster-Thread beschreibt? Der Aufbau des Experiments ist ein einfacher LRC mit vorgeschaltetem Transformator. Durch feines Tuning wird eine stehende Welle geschaffen. Dadurch war er im Stande eine 250 Watt Glühlampe mit 3 Watt Eingangsleistung hell zu erleuchten und dies bei 50/60 Hz. So wird quasi nicht mal eine hohe Frequenz, geschweige denn eine Funkenstrecke benötigt.
Das einzige Problem ist das Tuning, denn selbst wenn man seine Hand mal unglücklich bewegt, ist der Resonanzeffekt kaputt. Kapanadze hat es halt irgendwie geschafft, dass die Last keinen Einfluss auf die Resonanz im Innern nimmt.
It really is so simple that you will laugh, at least for what is necessary to create OU.
Jack Noskills
Quote from: Free.Energy on August 22, 2012, 09:23:17 AM
All of which does not add more energy than you put into it in the first place, so how is it a requirement for an OU system?
You make LC circuit that has only R to slow things down. If R is zero it runs forever, remember Tesla experiment with cooled down wire that run for three years. Each cycle is copied to secondary, if no load then LC circuit keeps on running forever. The instant you connect your secondary to load there will be back EMF that opposes LC circuit, resonance is destroyed. Now source sees this and pushes more and power gets used. But if you take this power from secondary so that resonance is not destroyed, your primary LC circuit still runs forever and what ever power this source has circulating you can freely take. Very simple to understand yes ? TK figured this out, so did v8karlo and so did I. Just crank up the frequency and power circulating in the source and energy abundancy is yours, just like Don Smith has said.
