0 Members and 56 Guests are viewing this topic.
leo48
Thanks Bernhard
this means that this transformer when used with the network to 50 hz
can deliver up to 400 w.
Also being used in other frequency wires would not be appropriate to bring
a higher power.  ;D
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
Zeitmaschine
Quote from: Shokac on August 23, 2012, 06:23:38 AM
Spark gap is use for automatic change frenquency in RLC circuit. Spark gap make resonance!!
Because of this, TK use HIGH Voltage. With small voltage no spark!
Then why is it that nobody can successfully replicate this device? Because the assumed principle is totally wrong?
Quote from: Shokac on August 23, 2012, 08:16:06 AM
NO. Kapanadze say "Radi, radi" that menas "Working". Spark is fire, but spark is very small. When put load on, fire is strong. This is "Automatic resonance with spark gap".
»Radi, radi« means »spark is working«, or does it rather mean »it will work anyway without spark«? ::)
Test: Use MOT, connect to secundar capacitor (8pF, 2500V) and spark gap in series. Measurement current to primar (2.30A) and measurement current in LC Spark gap circuit. Current is 23Amps.
Then this construction should run in self-sustaining mode. Ever tried it?
Shokac
Quote from: Zeitmaschine on August 23, 2012, 03:15:24 PM
Because the start with small amount of energy. You need 220V or more. No 12V or 24V!
Not working without spark or electronics with automatics resonanc circuit
I try all about I talking!
Regards!
a.king21
Quote from: forest on August 23, 2012, 07:59:08 AM
I have a question about spark gap. In 2004 video TK first looked at spark gap to see if it's working then the other guy switched on bulbs. is the same sequence actions required for this new aquarium device ?
The device was started by the application of a pp3 (small 9v battery). At the same time a switch was held down. Then the 2.5 kw device started, all at once. It is possible that he was holding it until he saw the spark gap firing of course. That then is his indicator that the start capacitor has enough power to run the device.
TK uses high frequency-high voltage maybe. I do not think his high voltage goes too much into the KV range - maybe 5 kv.
TK is quite capable of producing a "no spark gap visible or audible" device if he wants to.  I asked for aquarium 2 because I wanted to test my theory about the spark gap acting as a load limiter and I was right. He also did not put the coil capacitors of aquarium 1 on show - indicating increasing paranoia. It took me a couple of months to convince him that I did not want a mechanical device. I told him I could see through his charades.
He simply does not understand the patent process. So he is acting like inventors did in the middle ages - wanting money - but afraid to show the device in case someone steals it.
Zeitmaschine
Quote from: Shokac on August 23, 2012, 03:34:05 PM
Then why is it that TK can start the aquarium device with a 9V battery?
