0 Members and 101 Guests are viewing this topic.
a.king21
wattsup: Spark gap. It depends which way you look at it. Because the device loops - both you and I are correct.
We have to keep remembering that the device loops back on itself. I call it an infinity loop. Anyway I've read his patent and my interpretation of the diagram I posted is that the spark gap is used as a current limiter.
Starting: I already posted that today earlier.
starcruiser
Quote from: wattsup on August 23, 2012, 05:02:29 PM
@a.king21
Well, I ain't gonna learn to play the fiddle while your saga with TK will lurch on in an endless quagmire of mutual litigation. Like I said, "high return investment always means high RISK", with great emphasis on risk.
I only ask that you do not use this venue as your mode of showing your great displeasure of TK, which is very understandable I must say. But I think guys hear have enough on their hands. But don't forget that you paid for a demo and you got a demo. I don't know more about it but in those countries, the Law may have a different flavor.
@all
First off, the wire and the chair. That wire is not going into the ground wire. It just looks that way. If it did, the observers would have seen it, especially when the device was lifted in the air. It is just one of those crazy angle shots that create an illusion.
Next, the spark gap. The SG is not on the output side of the system. It is on the pre-drive side keeping the pulsations to the main triple coil(s).
Next the negative of the HV output. Even though it is connected to the terminal 3 of the third coil, it is still not going anywhere because the 3rd and 4th terminals are all in parallel, hence he is using a virtual ground for the negative. This can cause many effects that we do not know anything about yet, especially when you consider the other side of the 1st and 2nd coils are going to the Coily Coils. This means that it is even possible that the primary side of the 1st and 2nd coils are not being pulsed but he is actually using them as a step-down to feed back signals to the pre-drive side. Otherwise he is using those two primaries as standard driven pulses, but I would not put it past TK to use the Coily Coil as a simple fancy looking short circuit across those two secondaries, again to feed back energy via the primaries.
Next, about the coax wire he was anxious too receive. Give me a break man. This cannot be possible that there is no coax in Georgia. I would believe it more if you told me there was no HV wire for the TK coil in Georgia because that is harder to find the right type. But coax, that's a dime a dozen. Now, I am sure if TK needed the HV wire, he would not say this to anyone and all his insiders would call it coax.
Hehehe.
I don't think TK planned on us finding out so much.
@a.king21
One question if possible. While TK was starting the system, can you remember the actual step by step method he used to start it up and did you notice when the spark started, which of the two switches he used. This is important because we can follow the switch wires back to see which area of the build they are going to and this can help us figure out some more insights.
wattsup
Wattsup,
CAn you provide a diagram of what you are indicating with the grounds?
Regards,
Carl
pix
Quote from: sparks on August 23, 2012, 11:14:37 AM
  Spark gaps not necessary huh.  http://en.wikipedia.org/wiki/Electron_avalanche  Why when I look at two capacitor plates seperated by a dielectric do I see the identical description of a spark gap?  What do you think was stinging Tesla back in the first paritcle accelerator ever devised?  What do scientists call fast electrons?  Why did Tesla like so many other scientists with 1/2 an ounce of integrity rail against making metals radioactive while you can make nitrogen radioactive with a 1/2life of 12 seconds.
That is what I am talking a long time.
Energy must came from somewhere.
Spark discharge is in fact an electrons multiplier.One electron initiates an avalanche, like chain reaction in nuclear process.
Isn't this a energy gain?
What we need?- A small capacitor charged to HV just to start electron avalanche....
Regards,
pix
wattsup
Quote from: starcruiser on August 23, 2012, 05:32:09 PM
Wattsup,
@starcruiser
I had posted @Bernhard's original circuit diagram that I corrected with present know wires, etc.
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg333270/#msg333270
See the triple transformer, so consider they are numbered 1, 2 and 3 from left to right. The right one is the HV output with the blue wire terminal #1 is the positive going to the load, but the negative grey wire #2 is connected to the second secondary in that coil at terminal #3 which "should be" the positive side of that second secondary. So the HV- is not going to a common ground but it is floating inside the three second secondary coils probably creating some major havoc.
Guys have to realize that whatever happens before the triple transformer is not really that important because TK has many builds, with 9v battery start (more complicated build) to the 2004 device, (much simpler build), but in all the devices, there is a common theme that has been divulged in the Aq2v.
Now all we have to do is develop a logical method of experimenting, get the TK coil built per this type and start trials. I have a good idea on the set-up but need to think more about it to ween out the bugs before I build it.
wattsup
Zeitmaschine
Quote from: Shokac on August 23, 2012, 04:44:14 PM
Why.....think.... 9V charge 12V or 9V capacitor.  (cca 80000 or 100000uF). This amount of energy is enough to start inverter (220V). After that device work itself.
Yes, that's it. Now thinking...
Question: Why using an inverter which provides 220V/50Hz when neither the lamps or the heater (load) nor the high frequency/voltage generator cares about 50Hz?
Answer: The heavy transformer, which is actually responsible for the generation of the over unity, needs 50Hz in order to work correctly.
