0 Members and 56 Guests are viewing this topic.
Gidfactor
ok guys greetings to all i have this diagram for a while now that i replicated it is a ozone generator but if turn the other way it performs magic,
ok it looks like TESLA cus it has rotatory spark gap being driving by a flash over mechanism, now what is strange abt it is that when u disconnect the ozone chamber and u connect a trafo it produce more output than input.
now in TK 2004 what i noticed from his demo was anytime he turns no his device there is almost the same sound as a motor, i know defiantly that the inverter has no cooling fun inside cus he claimed in his video that the inverter is only 300w.
so my guess is that he is using a rotatory spark gap in the TIN CAN and he is flashing HV over the AIR core coil.
remember guys he said ''IT IS SO SIMPLE''
TK WE ARE GETTING CLOSER.....
cheers....
Magluvin
Quote from: frankidel on August 24, 2012, 04:09:58 PM
Hi about having let say 2000 V 0.1 Amp or 200 V 1 amp.  If you use the 3 phase transformer, input 220 V X 1 amp = 220W, output 3 times 2200 V @ 0.1 Amp, do you have 660 W ??
But as you load the 3 secondaries, the primary amp goes up.
Are you saying you have tries this and these are your measurements?
MaGs
a.king21
Gidfactor: There was definitely no mechanical motion in the aquarium 2. I checked and double checked  and triple checked. And more. Definitely no mechanical movement at all. No hissing, no humming, just that haunting spark gap mocking us all.
No heat from the device, no cold from the device,  NOTHING.
NO VENTILATION HOLES IN THE PLEXIGLASS.
Just 2 kwatt heater. They had the window open, because of the heat.
But we know: The output coil pack is HV wire!
The device is LIGHT WEIGHT.
The device needs COAX CABLE BRAID to function.
The device has HV shielding and is susceptible to storms.
The output spark gap is current limiter (To prevent an INFINITY LOOP from destroying the device)
We suspect: flyback from tv.
We suspect: copper coil capacitor.
The device is so simple you will laugh.
(I'm not laughing).
a.king21
Gidfactor: Do you have a video of your device? It is very interesting.
leo48
 8)
This morning watching carefully the coil I found that the first two layers
longer are wound cw  and ccw are four layers shorter.
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
