0 Members and 49 Guests are viewing this topic.
Gidfactor
A.king  I use to have a working model but lost them through flood, but don't worry have something new for everybody in this forum IE to end this TK fever, I know what he is doing and I have started the replication I will post a video and pictures soon when am done, but for everybody to start with try research on CDI circuits any of them the best one are the automotive CDI with double transistors drivers and increase or double the size of the ignition coil.
Trust me you will be amazed what you will discover, we should also remember that TK is not EE but just a draft man so he is smart in hide something very simple.
I live on an offgrid solar system I built myself since 1998 and still working, one time I noticed something strange I was in my garden trying to put bug wires on my fence I got shocked when I touched the fence with on grounding from my inverter so that was strange because my inverter is not grounded or earthed at all and is mounted on the wall too I don't even have the government grid coming to my place at all my inverter has only L and N no E I have not attached any cable to the chassis of the inverter whatsoever.
I grabbed my Fluke and measured earth and one live of my inverter hmmm and guess what I had 242volt @ 50Hz current was not strong because I could only power a 10w bed side radio, and lamp the inverter did not register any load because I made sure I was not fooling myself.
When you put a step up transformer in front then a different thing happens u could power a bigger load now 100w lamp to full brightness but volts drop to 239volt and still the inverter see nothing when take the earth off the ground everything stops.
When it rains or if the ground or earth is more wet it is even better more current and volt also it did not interfer anything like my neighbour's power supply I find that very strange to believe if TK says so.
Because remember you can steal the government power by just stick a copper rod in the earth and taking only one live wire from the house or simply pluging your device on the L and E your wall power socket, the gov knows it so sometime they protect these intrusion by putting ELCB(Earth Leakage Circuit Breakers) in your electric meter installation.
Just try it you will see I think many guys here already knows what am talking about.
So TK is :-
1. using an inverter it can be any capacity it is just to start and power the CDI circuits and achive 50hz.
2. Instead of using just L and E of the inverter rather he uses the inverter to power a HV CDI which hates electrical storms(I think we know this already) try starting ur car in a raining day your chances of getting strike by a lighting is high, now this CDI is going through a step down air coil because that is the only way to step down the HV and gets more amps.
3. I noticed that sparks from the aquarium was not continues but more like controlled sparks that brings us to CDI of automotives.
4.CDI have tremendous apatite for low input voltage and high voltage and high capacitive current discharge.
All this is not possible if u pull the earth wire(can anyone tell me if they ask TK what will happen if the ground is pulled)
The circuit can operate without an earth but you will have to incoperate NMR.
Ok guys I will end here stay tune I will be posting stuffs soon, TK knows we are getting closer so he and his team are make the designs very difficult and complex with sprayed trash circuit boards lol I tell you this guys TK 2004 video is where Everybody should start from Because all the truth and secrets are there very plain and simple.
We need a Russian translator to translate or give us subtitle to the TK 2004 TIN CAN edition.
TK WE ARE NEAR.....
Gideon....
Gidfactor
a.king this is for you am not finished but will finish soon i promise i will post my results and drawings when am done,i was working on a similar device until i bumped into this forum is quite better than TK... you will see when i post the schematics is all based on CDI and a core i have created i called it ASYNCHRONOUS CURRENT DEFLECTION CORE is much better than TK no string attach whatsoever.
Hoppy
Quote from: Gidfactor on August 25, 2012, 04:23:52 AM
Gideon....
I wish!! What country do you live in?
Be aware that inverters should always be grounded unless it can be ensured that all output wiring and appliances are double insulated. There will be a potential between the live wire of the inverter and ground when measured with a high impedance meter and this can can be considerable due to induction. This is why inverters are supplied with an earth connection screw. Yes, the potential will vary with ground conditions. I get 190V but cannot see any sign of a hot filament in a 10W mains lamp when connected between live and earth.
I look forward to seeing your setup details.
Hoppy
Jon_sparky
Quote from: a.king21 on August 24, 2012, 08:25:24 PM
Gidfactor: There was definitely no mechanical motion in the aquarium 2. I checked and double checked  and triple checked. And more. Definitely no mechanical movement at all. No hissing, no humming, just that haunting spark gap mocking us all.
No heat from the device, no cold from the device,  NOTHING.
NO VENTILATION HOLES IN THE PLEXIGLASS.
Just 2 kwatt heater. They had the window open, because of the heat.
But we know: The output coil pack is HV wire!
The device is LIGHT WEIGHT.
The device needs COAX CABLE BRAID to function.
The device has HV shielding and is susceptible to storms.
The output spark gap is current limiter (To prevent an INFINITY LOOP from destroying the device)
We suspect: flyback from tv.
We suspect: copper coil capacitor.
The device is so simple you will laugh.
(I'm not laughing).
A copper coil has capacitance yes. Please can someone say or explain what exactly kind of "copper coil capacitor" Tk may be using and looks like - that resonates in pairs or as three, better still could be made to act like an electron pump or heart, a self-running self-sustaining pump.
