0 Members and 381 Guests are viewing this topic.
Hoppy
@ Wattsup,
Yes, it looks like its from coax cable and for HV use. But, was it built for the aquarium design or for an earlier project and just placed into the aquarium in a prominent position as eye candy - time will tell.
Gidfactor
Quote from: wattsup on August 26, 2012, 10:03:03 AM
@Gidfactor
Welcome to the forum.
THANK YOU VERY MUCH WATTSUP...
In the patent you put up, it seems to fit well into the required function of a driving circuit. The only problem may be that this circuit incorporates some bleeding resistors to keep the discharge cap(s) from over charging during faster discharge rates and I am worried that this will dissipate too much energy. Of course, if the overall device ultimately produces so much OU that any dissipation would be deemed frivolous, then that would not be a problem.
@all
OK, about the blue TKc wire.
OU member @dllabarre sent me a PM yesterday and I think it is appropriate that I copy it here. I am sure he will not mind because he is the one that put this idea forward.
OK, so I looked closer at the blue TKc wire and took some closeups of the already available images.
Basically these shots show that the blue wire has an internal dielectric (white).
There could be an aluminum shielding between the blue layer and the white layer. Also, let's say this same wire came originally with a black outer insulation. By removing the outer layer, you will then see a layer of shielding wire that can easily be slipped of the wire length and used as the device ground lead. The remaining wire blue is as we see it but I would suspect that is has an inner aluminum shield as well which is typical of such coax wires.
So the coax should have the following layers, from outer to inner, to be a good candidate for a TKc.
Layer 1: Outer coating. Usually black.
Layer 2: Ground wire meshed shielding.
Layer 3: Blue insulation.
Layer 4: May or may not exist as am aluminum foil layer.
Layer 5: White dielectric.
Layer 6: Center conductor.
Man, oh man. So coax makes sense and his requirement for a more special coax type with more layers then usual would be correct.
Getting closer and closer. Let' keep on going.
When we were doing tests with the Caduceus coil, we had the HV leave source, then through an Avramenko plug, them to spark gap/capacitor and then to the Caduceus primary. Lot's of energy was lost in the spark gap.
The present Aq2v shows that the HV+ goes DIRECTLY to the load, then to the TKc, then to ground. This is the testing I want to do next and see if frequency is a factor.
wattsup
frankidel
About the coil capacitor, with the coax cable, i think you have capacitance between the copper wire and the shield. so if you coil that cable do you hace your coil capacitor ???
27Bubba
@wattsup, and all
In my post "  Reply #13289 " I have mentioned that it is possible that TK is using a coax or part of it. I'm pretty convinced seeing different types of coax cables with various sizes of center conductor and insulating that he possibly used in coil HV end .. Just a thought.. ;)
Dom Tesla
Maybe .... there is a asymetric capacitor involved?! I dont know... that Idea just popped up in my brain.... Maybe... some kind of asymetric coil capacitor he creates thru that coax cable?! I know it sounds senseless... but we gotta think out of the box... dont we?! I mean What would it do?
