0 Members and 336 Guests are viewing this topic.
forest
Quote from: frantz on August 27, 2012, 01:43:13 AM
Hi angrySientist,
I think you have a good look on problem...
I would like to remind some patent file which was posted by FreeEnergyInfo on this topic (or other) few months ago...
I think, you should read details about magnifying coil, what from is amplifying, etc.
On the beginning this look like out of topic, but if we will take a different source of electrons like in that patent (there is semiconductor) we should to have resolved problem. Just read.
F.ex.
let's look on self looped ordinary solenoid coil. If we will put this coil inside alternating magnetic field, whats happens? Nothing special. We will to have generated maximum current in self-looped coil which will be a equivalent of the external magnetic field ..., but...
If in the same circuit in the same self-looped ordinary coil we will pump in some amount of electrons (lets say 10 or 100 times more like in normal state) we will have 10 or 100 times larger current in using the same external AC magnetic field like on the beginning. What is a current? This is how many electrons flowing in time unit...
Next question is: How to pump in more electrons inside self-looped coil? I think we should use this coil like one negative plate of the HV capacitor. Second one will be a second coil (without self-looping or with, no matter, because there not will be electrons and if no electrons when no current with impact to output coil (third one))
Next thing is: Why we should still pump in electrons inside this coil (plate of HV cap) because this "plate" of capacitor have a self-discharge in short time. For keeping this electric charge inside coil on some level we must still pumping electrons (f.ex from ground - this is unlimited tank of electrons ;) ) via SG f.ex.
what is more interesting there. We can use LF and iron core for amplify magnetic flux... ;-) but we must remember about good insulating this two coils (HV plates).
My explanation of frequency of SG in Aquarium 1:
If we don't have load or load is not large, frequency of SG is high because electrons are not stored by the current flow inside coil and electrons escaping from coil (self-discharge), when load increasing, current increasing, too and electrons are strongly related with coil and SG don't must so often recharge a potential of this coil.
Aquarium 2
Why guy who's touching ground nut outside building was very careful? because  positive HV was connected to GND via SG... ;)  for sucking electrons from ground...
One thing that did not fit is HV wire diameter. In my opinion this wire should be thick for high current in self-loop, but maybe something we do not know...?
Let me know what do you mean about this.
frantz
Good. Remember : electrostatics.Like 5-10kV or more then 1 amper is enough, right ? ;-)
frantz
Forest,
I can not to agree. Idea which I described has a different theoretical assumptions.
High potential is only for increasing the number of electrons inside self-looped coil that's all. Did you read attached pdf file?
The difference of potentials on self-looped coil should be very small (between different points of this coil), I don't want to measure difference between coil and GND because do not need to do anything. HV is only required to charge negative "coil-plate" (more electrons inside wire) that's all. In my opinion more important is current generated inside looped - coil (high current = high magnetic field outside this coil).
Hoppy
It would appear that TK may have read the Barbat patent! The race is now on to find how TK built the photon based current amplifier and where its located in the aquarium  :) . That explains what the arrows signify above the current amplifier block in the schematic!
frantz
Quote from: Hoppy on August 27, 2012, 04:57:51 AM
It would appear that TK may have read the Barbat patent! The race is now on to find how TK built the photon based current amplifier and where its located in the aquarium  :) . That explains what the arrows signify above the current amplifier block in the schemstic!
And if you could approach the subject seriously, no kidding. Thank you.
I described how to replace photons ....
Maybe this what I described above is not a TK solution, but this is some idea (and explanation) from where can be additional energy. Not from black hole.. ;)
Hoppy
Quote from: frantz on August 27, 2012, 05:02:05 AM
Maybe this what I described above is not a TK solution, but this is some idea (and explanation) what from can be additional energy. Not from black hole.. ;)
So lead the way Frantz
