0 Members and 383 Guests are viewing this topic.
frantz
Quote from: Hoppy on August 27, 2012, 05:15:17 AM
So lead the way Frantz
Hoopy
I need all yours brains, maybe I'm wrong, I don't know. But you all are required in this subject.
Maybe you will have better idea, or better point of view, let give it on forum.
thanx
P.S.
I think everybody are tired on this forum, we need some small success.
Next thing is coax cable. this can make sense. If we put  HV potential to center wire and push -HV potential to shield wire which is looped and thick we have what I describe above...
coax cable have good silicon insulator between central wire and shield. I think this insulator can work good with few thousent V...
Hoppy
Quote from: frantz on August 27, 2012, 05:20:27 AM
Hoopy
thanx
OK, I'll be serious and put my FE hat on.
If it is true that this device is really as simple as TK tells us and assuming that the current amplifier is photon based (given that he shows the arrows on the schematic), then he has found a simple method of producing it and there is enough information in the patent to give us a head start. However, there is still also the possibility that he tried and failed to produce the CA and tricked us. I'm happier to believe that some form of energy transmutation is involved, than believing that he has simply gained energy as result of inductive feedback, which is a nonsense at the level needed to run the electric fire. The Barbat patent may well be the key.
Gidfactor
hi guys, in the demo with the group under the basement if you examine the video closely you will find out they had CDI(white rectangle box in image 0690) and hey did i see COPPER BRAID and HIGH IMPEDANCE BLACK RF CABLE, TK is not using FLYBACKS in all his devices he is using an old Russian two transistorized CDI generator maybe from that old car being packed at the compound in his rented apartment(who knows).
can someone please find out or tell us what sound is coming out from aqu 1 and if you watch the full demo video you will also noticed that he was hesitating to leave the demo running for a longtime, also you will noticed that just getting to the end of the demo that spark gap sound seized and he quickly turn it OFF he did not turn it back on again.
he had burn something you can tell from how he is sniffing around his device.
i am much interested in the startup sounds in all his device demos the CAMERA is able to pick them up and stabilized the output for smooth recording.
i tell you guys it will mean a lot if we can find out those sounds and the precise tandem preset sparky gaps (papapapa).
cheers.....
frantz
Quote from: Hoppy on August 27, 2012, 05:34:30 AM
I'm so glad, you are talking now like a scientist (researcher).. ;) Continue please.
mrzlica
Hello!
About the coiling, maybe we should examine more carefully the device which was made for Wesley.
http://freeenergylt.narod2.ru/kapanadze_2/
I'm referring to coax cable. (hv cable), maybe someone will see something new!
[/font]
by
