0 Members and 69 Guests are viewing this topic.
frantz
Quote from: mrzlica on August 27, 2012, 05:44:36 AM
Hello!
About the coiling, maybe we should examine more carefully the device which was made for Wesley.
http://freeenergylt.narod2.ru/kapanadze_2/
I'm referring to coax cable. (hv cable), maybe someone will see something new![/font]
by
these pictures refute my theory, because there is no loop in the cable shield ... :(
but nothing is lost, it may be different at each other looped coil and is well hidden ... :)
frantz
And watch,
in Barbat solution is required weak exciting magnetic field for starting.
And strange coil (in Aquarium 2) which looks like a donut is a outside exciter...
Maybe Tk divided magnifying coil on two parts and connected them together parallely, and we see only one part of this coil???
Gidfactor
Quote from: wattsup on August 26, 2012, 11:22:12 PM
@all
So far I only found one image on the coax I need. The bottom one of image below. If you take off the top layer and slide off the shielding, you get the same wire type as the TKc. hehehe
But the web site I got it off did not have any spec on it, just the image that I found here...
http://csb-tel.com/portal/node/91
So I agree this cable will be harder to find.
Also I am putting up a chart on coax power ratings. Pretty impressive I think.
We also need someone to look into low cost CDI's and look into the pin outs to figure out how to use it.
@stivep
That is one beautiful piece of equipment, full of so many goodies. You could not even buy those C-cores for that price. hahaha What a deal.
wattsup
Added:
Just figured it out. It is a triaxial cable with the first layer and shielding removed. TRIAXIAL is the key.
THIS WAS USED BY THE UNDER BASEMENT GROUP.....
leo48
QuoteMaybe Tk divided magnifying coil on two parts and connected them together parallely, and we see only one part of this coil???
What is this yellow looks like a coil?
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
frantz
Quote from: leo48 on August 27, 2012, 06:37:17 AM
Leo48
I don't know what is this yellow. But donut coil can be e exciter...
Maybe this yellow thing is a some kind of core which moving magnetic flux to the blue coil? (iron tape???)
