0 Members and 36 Guests are viewing this topic.
Gidfactor
ok guys sorry have to travel so will not be on the forum for a while now is a family thing....
cheers.... 8)
Zeitmaschine
Quote from: Gidfactor on August 25, 2012, 04:23:52 AM
A.king  I use to have a working model but lost them through flood, but don't worry have something new for everybody in this forum IE to end this TK fever, I know what he is doing and I have started the replication I will post a video and pictures soon when am done
Quote from: Gidfactor on August 27, 2012, 07:00:26 AM
cheers.... 8)
So this essentially means the replication attempt has failed. :(
It is also a pity that the working model got lost in a flood. :(
But never mind, a lot of FE things were lost during the ages. :(
And now, the TK fever can go on ...  :)
Peter Lindemann -- Electric Motor Secrets
stivep
Quote from: frantz on August 27, 2012, 01:43:13 AM
Aquarium 2
Why guy who's touching ground nut outside building was very careful? because  positive HV was connected to GND via SG... ;)  for sucking electrons from ground...
One thing that did not fit is HV wire diameter. In my opinion this wire should be thick for high current in self-loop, but maybe something we do not know...?
Let me know what do you mean about this.
frantz
I found your explanation interesting and very exotic.
It would be good to put it in more graphical form for the  audience to absorb.
And honestly I did not get  all parts of that picture at once.
But   I've  got  intrigued by your article...
Fantz quote:
the wire should NOT be thick,
Rule #1
The higher the frequency and the higher the voltage the smaller the diameter of wire is required.
Rule #2
In resonance the thickness of the wire  can go to infinity
or
can be minimized  to infinity.
Problem starts only after you go out of resonance...
Some of factors to analyze.
Please understand word ANTENNA as wire in resonance
including one side grounded wire.
Counterpoise is part of an antenna (ground immersed or grounded) as well
counterpoise  can be not grounded at all and serve as ground ( virtual ground)
When you hold  walkie talkie ( handheld) radio in your hand  the small rubber antenna acts with your body as  one dipole antenna or ground plane antenna  .Your body serves as counterpoise.
I addressed this to chief of scientific group about 10 minutes ago.
Below is the submitted material:
Subject  is related to THICKNESS
What is thickness of the  wire requirement in resonance
-series
-parallel
another words : how is current in resonance requirement being formulated versus thickness
is the physical thickens of wire  required >>>going to infinite minimum, maximum? when  circuit is in   resonance ?
Supporting material  for analysis and discussion:
1.
Resonant Antennas: Wires and Patches
Dipole Antennas http://memo.cgu.edu.tw/jui-ching/antenna2.pdf
Current distribution approximation
Un-normalized pattern
Radiating power:
For half-wave dipole
and
, , or  at exact
resonance.
Effect of dipole thickness
1. Resonant length: decreases as thickness increases
2. Resonant resistance: decreases as thickness
increases
3. Bandwidth: increases as thickness increases
2.
Insulated Wires: The NEC-2 Way http://www.antennex.com/w4rnl/col0105/amod83.html
This article says about thickens of insulation ( parameters of insulation)
affecting resonant  frequency approximation
A thicker diameter antenna wire lowers the frequency of resonance (the point where the SWR = 1.0) and lowers the range of reactance at any given frequency.
Larger diameter antenna wire lowers the wavelength at resonance. An antenna cut for ½ wave is actually less than ½ wave in electrical length due to using larger diameter wire. Therefore, for thicker wires the length of the antenna must be increased slightly.
A 1:1 SWR does not indicate that an antenna system is resonant. SWR is only the ratio between the impedances of the feed line and the antenna load. For example, we can connect a 50 ohm pure resistor across a 50 ohm transmission line and there will be a 1:1 SWR, but there will be no radiation from the resistor.
Any piece of conducting material will work as an antenna on any frequency. This comes from the fact that there is some small inductance in any wire, strip of metal, or resistor which will allow some radiation to escape into space. However, the main objective should be to build an antenna that will function primarily as a radiator of RF rather than as a generator of heat.
The only reason for building a sophisticated antenna is to control the radiation pattern
The radiation pattern is controlled by focusing the radiated energy. The geometry of the antenna and the proximity of nearby objects are the main controlling factors.
The total amount of energy radiated from an antenna remains constant for a given transmitter output power. When this energy is focused, the energy radiated in one or more directions will be increased, and the energy radiated in other directions will decrease. This is what gives an antenna "gain".
Anything that enters into the aperture of an antenna (1/8 wavelength on each side of a dipole antenna) will affect the operation of the antenna. The effects are pattern distortion, skewing of balance, change of feed point impedance and resonant frequency shift.
Sometimes it is desirable to cause intentional aperture interference. Placing other conductors into the aperture will cause severe pattern distortion. This can be beneficial when this distortion takes place in such a manner as to focus the radiated energy into a tight beam. This is the basic operating principle of parasitic beam antennas.
Wesley
semenihin-77
Quote from: Zeitmaschine on August 26, 2012, 02:45:26 PM
Nothing new. The blue wire could be the same blue wire (double insulated for high voltage) as seen in the green box video. I still don't understand how this wire can be responsible for any free energy.
The fact that small spark and dancing - is charging the capacitor.
http://www.youtube.com/watch?v=-7eXZInkmow
or http://www.youtube.com/watch?v=L5nS7Q7p-E0
a.king21
A.king  I use to have a working model but lost them through flood, but don't worry have something new for everybody in this forum IE to end this TK fever, I know what he is doing and I have started the replication I will post a video and pictures soon when am done, but for everybody to start with try research on CDI circuits any of them the best one are the automotive CDI with double transistors drivers and increase or double the size of the ignition coil.
Trust me you will be amazed what you will discover, we should also remember that TK is not EE but just a draft man so he is smart in hide something very simple.
I live on an offgrid solar system I built myself since 1998 and still working, one time I noticed something strange I was in my garden trying to put bug wires on my fence I got shocked when I touched the fence with on grounding from my inverter so that was strange because my inverter is not grounded or earthed at all and is mounted on the wall too I don't even have the government grid coming to my place at all my inverter has only L and N no E I have not attached any cable to the chassis of the inverter whatsoever.
I grabbed my Fluke and measured earth and one live of my inverter hmmm and guess what I had 242volt @ 50Hz current was not strong because I could only power a 10w bed side radio, and lamp the inverter did not register any load because I made sure I was not fooling myself.
When you put a step up transformer in front then a different thing happens u could power a bigger load now 100w lamp to full brightness but volts drop to 239volt and still the inverter see nothing when take the earth off the ground everything stops.
When it rains or if the ground or earth is more wet it is even better more current and volt also it did not interfer anything like my neighbour's power supply I find that very strange to believe if TK says so.
Because remember you can steal the government power by just stick a copper rod in the earth and taking only one live wire from the house or simply pluging your device on the L and E your wall power socket, the gov knows it so sometime they protect these intrusion by putting ELCB(Earth Leakage Circuit Breakers) in your electric meter installation.
Just try it you will see I think many guys here already knows what am talking about.
So TK is :-
1. using an inverter it can be any capacity it is just to start and power the CDI circuits and achive 50hz.
2. Instead of using just L and E of the inverter rather he uses the inverter to power a HV CDI which hates electrical storms(I think we know this already) try starting ur car in a raining day your chances of getting strike by a lighting is high, now this CDI is going through a step down air coil because that is the only way to step down the HV and gets more amps.
3. I noticed that sparks from the aquarium was not continues but more like controlled sparks that brings us to CDI of automotives.
4.CDI have tremendous apatite for low input voltage and high voltage and high capacitive current discharge.
All this is not possible if u pull the earth wire(can anyone tell me if they ask TK what will happen if the ground is pulled)
The circuit can operate without an earth but you will have to incoperate NMR.
Ok guys I will end here stay tune I will be posting stuffs soon, TK knows we are getting closer so he and his team are make the designs very difficult and complex with sprayed trash circuit boards lol I tell you this guys TK 2004 video is where Everybody should start from Because all the truth and secrets are there very plain and simple.
We need a Russian translator to translate or give us subtitle to the TK 2004 TIN CAN edition.
TK WE ARE NEAR.....
Gideon....
Gidfactor: Don't write the Gidfactor experiment off. I tried it yesterday and my battery powering the inverter became live.
I earthed the battery through a circuit containing 2 small flybacks. I heard a buzzing noise through the flybacks.
After a few minutes there was a burning smell. Then I realised my flybacks were red hot.
It could be nothing, maybe a short through the earth. Or it could be everything.
I am still investigating.
