angryScientist
Quote from: Zeitmaschine on August 27, 2012, 07:25:19 PM
No problem! ;D
I'm with you. A very simple device is that what we are looking for!
Since all my experiments (and that of others) with spark gaps have failed so far (to produce free energy), I'm convinced that the TK principle has something to do with Back EMF. Reverse the Back EMF by some appropriate means, thus instead of having the Back EMF working against you, let it work with you ...
I'm not sure you guys are thinking of back EMF in the right way. You do know that back EMF flows in the same direction as the original current? It doesn't flow backward to the voltage you apply to a coil. It flows in the same direction.
For example, you take a battery and connect it to a coil. It takes a while for the current to start flowing. Now you disconnect the battery the current stops flowing but before it stops completely you get a back EMF that flows in the same direction as the current that the battery was producing.
The reason it's called a back EMF is because it's at the end of the flow of current you applied. Kind of like what they call a "Back porch" in a video signal is at the end of a scan line.
a.king21
Zeitmaschine and others re Lenz and back emf. THIS IS PRECISELY WHAT JACK NOSKILLS IS UP TO.
That's why I say he is close.
Anyway some important information next:
a.king21
In 1996 Kapanadze powered his first free energy device. It was ...... 1 KWATT !!!!!!!!!!!!!!!! It ran for three months.
I have been told inside information that sometimes the Kapanadze device takes a whole day or more to start.
In the aquarium 2 video Kapanadze kept the team waiting for 5 days, and then postponed the actual day till the afternoon because of storms.
Ask yourself the question - How many of us free energy researchers would dare experiment with a 1 K watt device as our first foray into FE? And use Mains electricity??  Think about it deeply.
I thank Gidfactor for providing the missing link. We've got him now.
Here's what I think happened.
In 1996 Georgia was coming out of a serious civil war. People were desperate. One thing that was going around was how to steal electricity from the grid.
Here's how they did it.  They  disconnected the neutral wire from their appliance. Then they put an earth rod in the ground and connected their devices to the earth rod. So the live was from the electricity main, and the earth rod wire became the neutral.
That way the meter did not register any power. They had "free" electricity.
I think Kapandaze took this a stage further and used an inverter to produce his electricity.
2 He needed more power so he used a flyback or a CDI unit so that he could use the flyback or CDI  unit as a  LIGHTWEIGHT transformer and use  light-weight wires.
3 He looped the device. Output into input.
4 He put a spark gap across the load as an infinity loop limiter.
I've been experimenting with the Gidfactor phenomenon.
Here's what I've found.
Scalar waves appear out of nowhere. But you have to tease them out.
Sometimes it works. At other times, the same circuit refuses to work.
Now look at my version of his patent again, with this new knowledge.
He puts the load from the LIVE wire straight into the GROUND! lol
I'm convinced we've got him at last!
angryScientist
I looked it up. There is a whole lot of nonsense given when I Googled it. I'm not talking about a "counter EMF" or "an induced back EMF" I'm talking about a Back EMF from a coil.
A magnetic field acts much like mass does. It opposes change. It doesn't like to be created, in fact it produces that "counter EMF" in the things around it that oppose it's creation. Once it's created it doesn't like to stop. If the current has been flowing for a while the "counter EMF" is no longer present in the things around it because it has died down and that "counter EMF" only appears when the magnetic field changes. If you try to stop your current flow, the magnetic field that it is creating will start to change and produce another "counter EMF" in the things around it that will oppose it's change, i.e. will try to keep the current flowing. That trying to keep the current flowing is what I have been taught is called "back EMF".
http://www.youtube.com/watch?v=aSmMFog10D0
MIT Physics Demo -- Back "emf" in a Large Solenoid
The description states;
"A large solenoid is connected to DC power through a knife switch.  When the switch is closed, the current builds up to approximately 30 amps. When the switch is opened, the solenoid attempts to keep the current flowing, creating a huge emf which ionizes the air in a huge spark."
Note "keep the current flowing" and "huge emf". That is MIT!
yfree
Quote from: a.king21 on August 27, 2012, 10:02:04 PM
I am very sorry, but as a physicist I have to be blunt.
Lenz law has never been beaten in our part of the Universe.
Back EMF has never produced any extra energy.
However, this does not mean that back EMF cannot be used to invoke phenomena that convert energy from one form to the other. Energy must always come from somewhere. The fact that you do not see the source of energy, only means that the source is well hidden.
This is just a friendly reminder. :)
