0 Members and 98 Guests are viewing this topic.
Davi
vdomov
Quote from: yfree on August 27, 2012, 10:49:12 PM
I am very sorry, but as a physicist I have to be blunt.
Lenz law has never been beaten in our part of the Universe.
Back EMF has never produced any extra energy.
However, this does not mean that back EMF cannot be used to invoke phenomena that convert energy from one form to the other. Energy must always come from somewhere. The fact that you do not see the source of energy, only means that the source is well hidden.
This is just a friendly reminder. :)
Yes @yfree This is 100% the True. Lets look from Principle Discovered by Ismael Aviso: http://www.youtube.com/user/ley858
http://www.youtube.com/watch?v=10JY4agHjE4 Aviso Tech Ambient extraction & basic principles 1- 3
http://www.youtube.com/watch?v=uEtxb6skBCE Aviso Tech Ambient extraction & basic principles 2-3
http://www.youtube.com/watch?v=RrbChoUe7B4 Aviso Tech Ambient extraction & basic principles 3-3
http://www.youtube.com/watch?v=tlm6VjieRJQ Aviso self charging motor 1 of 6 " BREAKTHROUGH "
http://www.youtube.com/watch?v=_hYxFWINuvI Aviso self charging motor 2 of 6 How I found problem & solved it
http://www.youtube.com/watch?v=Vb1HcyIKAFg Aviso self charging motor 3 of 6 TESLA Principles ( spark gap) & why is not applicable now MVI
http://www.youtube.com/watch?v=78Mfg1CBPrc Aviso self charging motor 4 of 6 About IGBT & other power switching modules MVI 1456
http://www.youtube.com/watch?v=g0Aj137A7kg Aviso self charging motor 5 of 6 Evgray similarity & advantage MVI_1459.mp4
http://www.youtube.com/watch?v=im2TvLXW5bc Aviso Self charging motor 6 of 6 EVgray How it works & disadvantages MVI_1466.mp4
And the key is given by Steven Mark (see attachment).
Quote from: Steven Mark TPUIf you look in Morgan Jones book, Valve Amplifiers, 3rd edition, on page
262 he says, The inrush of current through the filament interacts with the earth's
magnetic field to produce a small kick.
In Resume the Earth's magnetic field may be a only 0,5 Gauss = 0,00005 Tesla, byt it is not Still and is interact with inrush current in wire. So here is the long seeked hiden source of energy for Steven Mark TPU, for Ismael Aviso and maybe for Tariel Kapanadze so.
To make experiments with earth magnetic power kicks. We just need: a 6inch piece of wire, Voltage source(Power Suplly or Battery) and some expensive impulse traker osciloscope to see the results...
Or Back EMF motor coil impulses. Run Trough Ambient extraction Air core masive wire Coil to charging the capacitors i.e. Ismael Aviso Setups.
slapper
Quote from: Waves on August 29, 2012, 10:06:14 AM
Aquarium spark frequense is 10 Hz, see picture
interesting Waves.
i recall stivep saying Tariel was going to build a 10 hertz rig.
back in the woodpecker days they were saying the frequencies would be 16 hertz, 10 hertz and 8 hertz. not sure how accurate that is since i'm going from memory.
how close was Tariel to the woodpecker source. probably doesn't matter. i don't think it has been active for a while.
we are not alone :)
verpies
Quote from: Hoppy on August 29, 2012, 09:09:15 AM
One possible explanation is that he used an external power source brought in through wires concealed in the 'earth' braid. This source of energy may have been sufficient to to run a powerful high voltage inverter with the help of the battery, such that the battery could act as a no-break power supply in the event of a grid power glitch which caused short interruptions of the energy supply to the device. In no load periods, the external power source would be able to charge the battery. This approach would enable the external supply conductors to be minimised in cross sectional area. It would also allow for the braid to be disconnected for a short period to demonstrate that the magic was confined to the aquarium. It is in effect a compromise solution, yet it is simple. TK not being an EE may have viewed this approach as being quite clever...
Yes, this is a possible explanation. To be complete, it should be mentioned that conversion of high voltage, low current in the braid TO low voltage, high current for the heater, must be done at a kHz frequencies through a switching converter, in isolated topology (push-pull, FullBridge or Resonant ZVS) or non-isolated topology such as the buck-converter or split-pi converter.
Converting 2kW at 50Hz with a transformer would require a giant unit that could not be hidden.
Another far-fetched explanation is near-field magnetic induction. Such as turning the whole room into a giant air core transformer by hiding windings in wall, floors, etc...  This is far fetched because any larger conductive object in the room, would experience inductive heating and video cameras would be interfered with.
Avaramenko's Plug one-wire power transfer would create helluva RF interference, too.
Additionally, NF Induction and AV Plug transfers are sophisticated, expensive methods and most likely would be noticed even by non-technical observers, especially with sensitive video cameras and poking around with simple unshielded multimeters.
Well concealed HV low-current wires - not necessarily...
Jon_sparky
