Hoppy
Quote from: 27Bubba on August 29, 2012, 03:15:58 PM
"It would be sufficient for me to measure and weigh the "black box" and inspect it "external interfaces" such as the grounding braid and near fields around it for 4h."
If he (TK) have nothing to hide, he should have no problem with it at all.. ;)
A good look inside the braid and some measuring should do the trick. Oh, and not forgetting a look under that concrete slab outside  :) Unless this can be done, I fear that we could be guessing forever!
Hoppy
Hoppy
Quote from: verpies on August 29, 2012, 01:47:50 PM
Yes, this is a possible explanation. To be complete, it should be mentioned that conversion of high voltage, low current in the braid TO low voltage, high current for the heater, must be done at a kHz frequencies through a switching converter, in isolated topology (push-pull, FullBridge or Resonant ZVS) or non-isolated topology such as the buck-converter or split-pi converter.
Converting 2kW at 50Hz with a transformer would require a giant unit that could not be hidden.
Another far-fetched explanation is near-field magnetic induction. Such as turning the whole room into a giant air core transformer by hiding windings in wall, floors, etc...  This is far fetched because any larger conductive object in the room, would experience inductive heating and video cameras would be interfered with.
Avaramenko's Plug one-wire power transfer would create helluva RF interference, too.
Additionally, NF Induction and AV Plug transfers are sophisticated, expensive methods and most likely would be noticed even by non-technical observers, especially with sensitive video cameras and poking around with simple unshielded multimeters.
Well concealed HV low-current wires - not necessarily...
Just to clarify, I'm suggesting that normal grid mains current is fed through a separate conductor(s) inside the braid and the braid itself used as neutral. The mains current would then be full-wave rectified with heavy duty rectifiers and transformed down to heavily charge a set of high capacity batteries. The resulting DC current from the battery is then converted to HV and pulsed at a duty cycle just sufficient to minimise supply current but not to be perceived as pulsing the fire element. The battery would in effect act as a tank capable of supplying high energy pulses to the inverter, with the battery being replenished between pulses. The 'earth' braid is sufficiently heavy for the 'neutral' and I suspect there will be more than one inner conductor for the 'live'. Its not an elegant solution but I think it would work and its relative simplicity does seem to be in keeping with what and can only be described as pretty awful and amateurish looking overall build and earns the description as laughingly simple. I suspect that the actual power being consumed by the heater in the demo is considerably less than its actual power rating. I could imagine that TK may have been very serious about creating free energy but like us has experienced a whole lot of failed experiments over the years. Many of us cannot imagine how difficult it is for anyone having to survive in a society scarred by civil war and criminality.
Hoppy
cheappower2012
HI all,I noticed that no one got this,for this device to work you have to loop it.
No one asked where is it looped and how,notice the wires used to connect to the HV wires.
It could be a feed back point or an output point.
Qwert
Zeitmaschine
Quote from: Hoppy on August 29, 2012, 04:50:22 PM
What about mains failures? No Free Energy during a blackout would be somewhat embarrassing, wouldn't it?
Quote from: cheappower2012 on August 29, 2012, 05:53:13 PM
Are these real wires or just reflections? Remember TK works with smoke and MIRRORS. :)
Some more headaches: Where are the 9 amps for the load coming from? A pin that has no connection? Or has it? ::)
Any ideas with some physical basis?
