0 Members and 46 Guests are viewing this topic.
Hoppy
Quote from: captainkt on August 30, 2012, 05:29:21 AM
@Hoppy, why the fascination with braid and power feed through it? After all where is braid in green box, Island vid ,Booth vid or other 10 Kapanadze devices. They all obviously have a common (secret if you like) but braid is in full view so this would not be it. The braid if anything is acting as a capacitor and nothing more. I ran 2.5 KW through coax only lasted few minutes then heated up to dead short. DOES NOT MATTER IF LIVE OR NEUTRAL SAME LOAD/AMPS IN EITHER.
Keith
Just realised I missed answering your post. Firstly, I do not think the heater is consuming 2KW and I have already made the point that the power carrying conductors can be minimised with the help of a high capacity battery when the load is pulsed.
Hoppy
verpies
Quote from: T-1000 on August 30, 2012, 03:46:33 AM
And because most of folks choosen to chase TK goose here the entire info about yoke device now is hardly found in this thread....
Yes, the apparently working Yoke Device appears to be abandoned and everyone is distracted by the unreplicable tubular TK device, despite that the Yoke experimenters were much more forthcoming and transparent than TK.
The Yoke device is easy to build, if one has the proper ferromagnetic core, but it is hard to tune.
I was not able to detect a signal from nuclear precession (FID) in the black ferromagnetic core from a russian TV set Рубин 714, from 1kHz to 60Mhz Larmor Frequency, using the windings depicted in Aidas' diagrams.
Osiakosia, Itsu, energia9, dynoc, philm, Jdo300 and Wattsup also were unsuccessful with their cores. One of them made video of the attempt.
Thus, I am still waiting for Wesley to tune it successfully since his group has already done it at least twice.
Some info should be forthcoming from him, see below:
Quote from: stivep on June 02, 2012, 10:13:36 AM
Although Yoke experiment is considered to be dangerous I voluntary to go for it
I have  equipment  I need
that what I do not have but hopefully I would be able to  acquire is:
1.Alpha, Beta  Gamma  measuring equipment
2. electromagnetic omnidirectional  field strength  device.
That needs to be  purchased or borrowed from friends.
I have made contacts with  scientific community member to get help in this area.
Let's go back to working on the Yoke Device if no progress is made on TK's Tubular "black box" devices, by the time this thread reaches 1000 pages.
forest
Was that  braid silver  ? Was it magnetic ? Was it dismantled from coaxail cable or just bought alone ? Just curious.
verpies
Not the same current (Amps) if the voltage is different.
For example, at 3kV, less than 1 Amp of current is needed to transfer 2kW to the aquarium.
...and even enameled magnet wire can withstand 3kV.
P.S.
Without a rudimentary power measurement, such as this: http://jnaudin.free.fr/kapagen/kapagen33pio.htm
we cannot even be sure that 2kW indeed was dissipated in the load (resistive heater).
slapper
i'd like to see more investigation with the yoke approach as well. the core material i've got just doesn't cut it. the frequencies i detected were 13mhz - 16mhz where my capabilities are diminished.
i don't think the failure of the core was transmutation so much as the domains in the material polarized in scattered directions. the geometry sucks with the yoke but to get some signs of life out of it would require a separate overall toroidal wind. the core needs to be in a field that is as homogeneous as possible. there are examples where steven mark is waving a speaker magnet around one of his tpu's. this, to me, shows he is performing a magnetic shimming which is another one of those nmr terms. stronger overall magnetic field that the core is exposed to require a higher larmor frequency. the best effects to get the 90 flip are when the larmor frequency is switched on and off at specific phases and durations.
here is a video showing how a magnetic field influences magnetic resonance.
http://www.youtube.com/watch?v=1OrPCNVSA4o
it appeared that the yoke's larmor frequency was about 1.1mhz <-- my memory.
the resulting perpendicular field of the domains then need to be precessed at a lower frequency with a transverse wave to take advantage of the zeeman effect as much as possible and extend the free induction decay out. going by memory again but it appeared that the best transverse frequency for the yoke was around 180khz. the precession can be used for flux cutting or, using the example of the yoke, flux coupling with the other half of the yoke. precessional flux cutting is still used on the other half of the yoke for the energy extraction.
we are not alone :)
