0 Members and 217 Guests are viewing this topic.
FreeEnergyInfo
frantz
OK guys, I see flat calm o this thread... ;)
Let's back to the idea with looped coil. It is not important this coil will be ordinary solenoid coil or bifilar.
Let imagine this looped coil inserted in the middle of the positive electric field and the second half is inserted into negative electric field.
What's happens inside looped coil when electric field will pulsing? Nothing because electric charge will set when electric HV field is present and discharged when disappearing. NO current flow inside looped coil. Watch first picture.
And how to force current flow inside looped coil? We must to add pulse of small magnetic field which will force current flow inside coil in one direction.
How is easiest manner to do it? Rapidly discharging positive "plates"/coils of HV. And now, our looped coil is set like a resonator with a maximal current flowing inside its wire. What doing high current inside looped coil - generating high magnetic field. Rest is known
One thing is tuning: time of charging and dischanging (SG) must be carefully matched to the resonant frequency of our looped coil (resonator).
And we have free oscillator with high current and high magnetic field.
And for setting (decreasing) frequency of output oscillations we must insert capacitor with large capacitance in the loop of coil that's all. Rest is a tuning of SG frequency by changing the frequency of TVS (for settting how fast will be charged coils/plates of HV).
What is interested in this solution? We don't waste a power (magnetic field) for running oscillator. We get only magnetic field like final force.
In my opinion SG frequency is the coefficient of oscillator frequency. It is a multiple of 2. i.ex. SG frequency is 10Hz - oscillator could to have 20Hz, 40Hz, 80Hz, etc.
And scheme in this movie (last one) can be useful for increasing the efficiency of circuit... mayby not whole scheme but some part. There is good idea.
http://www.youtube.com/watch?v=3HNZaIjv2HA&feature=player_embedded
Osiakosia
Quote from: verpies on August 30, 2012, 05:41:37 AM
Yes, the apparently working Yoke Device appears to be abandoned and everyone is distracted by the unreplicable tubular TK device, despite that the Yoke experimenters were much more forthcoming and transparent than TK.
The Yoke device is easy to build, if one has the proper ferromagnetic core, but it is hard to tune.
I was not able to detect a signal from nuclear precession (FID) in the black ferromagnetic core from a russian TV set Рубин 714, from 1kHz to 60Mhz Larmor Frequency, using the windings depicted in Aidas' diagrams.
Osiakosia, Itsu, energia9, dynoc, philm, Jdo300 and Wattsup also were unsuccessful with their cores. One of them made video of the attempt.
Thus, I am still waiting for Wesley to tune it successfully since his group has already done it at least twice.
Some info should be forthcoming from him, see below:
Let's go back to working on the Yoke Device if no progress is made on TK's Tubular "black box" devices, by the time this thread reaches 1000 pages.
Hello Verpies ,
I just have finished my 2 Mhz power amplifier on the PA107DP chip .
This is why I did not have any new results regarding yoke device .
You are right . It is difficult to tune this device . Few times I have atchieved the sinus wave signals on the 50 turns coil but  did not understood the couses from which its depends ( from strenght of
generator output or the dimension  of U-shape turn) .
Hope will have the new results in september .
Osiakosia
Zeitmaschine
Quote from: frantz on August 31, 2012, 09:41:09 AM
They are all waiting for the new laws of physics to be officially established. :)
I still don't see how a coil with 78 ohms resistance can provide 9 amps of current at 220V. Hence
a) either new laws of physics are in place or
b) this circuit is a piece of legerdemain.
Anyone tried to power a 2KW (25 ohms) heater with such a small transformer (78 ohms secondary) the standard way by connecting the primary to the grid?
A KD502 can do 20 amps but only at 60 volts. That means the voltage of 220V must originate in the transformer. So this transformer is a magic one after all.
And the blue coil still does nothing except to cancel out its own magnetic field because of the reversed windings.
Qwert
