0 Members and 125 Guests are viewing this topic.
Dom Tesla
The main curcuit has to have a resonance frequency of 7,83 Hz. The load is grounded, and connected to the maincurcuit. The earth then resonates to the curcuit and high frequency resonance currents develope.  . The load is the Puller of higherdimensional/Ether energy wich manifests as current. The higher the voltage of the maincurcuit the more electron pull is possible in the same time.
a.king21
Quote from: Dom Tesla on September 01, 2012, 05:20:18 PM
I note what you say. Do you have any experimental evidence to back up your claims? Where did you obtain your information from?
wattsup
@all
OK, now I know it is extremely important not to have an aluminum layer in the coax. It is just totally isolating and cannot work in any way. Standard coax will never do because that aluminum layer is killing the effect.
I pulsed the center conductor with high voltage and got nothing on the shield. Nada. Completely dead. I have done this hundreds of times to know what to expect as a minimal result but the aluminum layer is really bad news. I was sweeping up to 1 mHz and nothing. TKc before and after load to ground and nothing. Regular coax is bad news.
So technically any wire that has a center conductor, a non-conductive insulation layer, then only a shielding wire (without the aluminum sheathing), then an outer layer, will do. That's why the triax cable with the outer layer removed and the first shield wire slid off will provide both the shielding ground wire and the proper coax to wind the TKc.
My local supplier may have a wire that fits the bill (except the shield wire may be straight and not woven) so today I will get some and wind a new one and test again.  If there is a response on the shielding, then I can continue.
Basically the wire TK is using does what? Well you have a center wire that will attract, with the right pulsing, an ether flux around the wire and the outer shielding is catching it. In the regular coax case, it is killing it because the aluminum is just keeping the center wire away from the outer world. (Exactly what it is supposed to do.) This explains why TK was so insistent on getting the right wire. Plus, he probably read SMs best-selling book entitled "Wire is Important". lol (Have to joke around here man).
More basic is that the TKc is a type of transformer with center primary and outer secondary all wound lengthwise. Why not? That is simple enough to understand. This way your coil is not bunched up in a primary first wind layer, and a secondary wind method that are both separate by their wind distances, or even mixed up in a bifilar arrangement. Your wire is wound one single primary lead that is always completely surrounded by the secondary not matter where the wires are located in a winding.
TK made a big mistake when he made the Aq2v, thanks to @a.king21 and gang. This design corners his mystique into well segregated smaller sections (like follow the on/off switches and battery start wires) that can be tested separately. The physical proof is undeniable that his build is one or two ways, but not endless ways like we have thought before.
Just one step forward at a time. Work out the variables and move forward.
wattsup
sparks
Quote from: Сергей Ð'. on September 01, 2012, 09:15:23 AM
From where come from "Legs" growing ?? From Tesla. Look this Tesla's setup for Lightning bolts (picture attached) !!
From the way Tesla described them, they just seemed to bubble from his machine.
READ THIS SEVERAL TIMES AND TRY TO UNDERSTAND WHERE COME FROM LEGS GROWING ?
Tesla's "MISSING" chapter 34 - Colorado Springs Notes:
"...it became apparent that the fireballs (read Free Energy) resulted form the interaction of two frequencies, a stray higher frequency wave imposed on the lower frequency oscillations of the main circuit.... This condition acts as a trigger which may cause the total energy of the powerful longer wave to be discharged in a infinitesimally small interval of time and the proportionately tremendously great rate of energy movement which cannot confine itself to the metal circuit and is released into surrounding space with inconceivable violence. It is but a step, from the learning how a high frequency CURRENT can explosively discharge a lower frequency CURRENT (for example 50Hz), to using the principle to design a system in which these explosions can be produced by intent."
    -N. Tesla
Was it a puzzle to us?
Draw an V-I diagram of λ/4 TT. (Secondary Tesla transformer). Draw another V-I diagram of smaller λ/4 TT . (Secondary pick-up Tesla transformer - Tesla bifilar). We have 2 Standing waves here. We need to impose bigger Standing wave on smaller one. How to impose ?? THE BACK EMF is what we need. THE BACK EMF is in fact counter act of AETHER on our disturbance !! BACK EMF is PURE OVERUNITY !! How to utilise tens thousands of stress and many KAmpers of current. The SPARK GAP. Tesla TT isn't EM technology(Vector type of energy flow) but scalar Technology. Tesla tech is Energy transfer without lose. No back scatering, no S-parameters. 100% energy transfer in pure Scalar Transformer. Same Tesla Technology in Floyd Sweet VTA or Stiven Mark TPU or Don Smith's board !! VTA was in fact Secret Nazi Ahnenerbe's project called "Silver Bell".
Extraction energy from AETHER for nazi UFOs. Again "Legs" growing from Tesla. Ottis Car UFO technology - Ottis Tesla's protégée!!
And what about Tariel Kapanadze. He can't be pictured among above mantioned.  I have informations but i can't proof them 100% so i don't public them that TK tech was "come" from some RAN (Russian Academy of science) projects made in Tbilisi from 1970 ...
My advice don't give a money to Kapanadze. Soon (on earth) will be much Free Energy and many FE devices so forget investment to Kapanadze and his "back side" team !!
If you want to make a good job give money to kids orphanage or better buy food (not genetically modified) or computers and give it to kids. Will be much much better than investment in Tariel Kapanadze "secret desease".
ps. I think one kid LIFE is WORTH MUCH than kapanadze life !!
   Tesla at the time of this writing had no idea about electrons.  In an electron cascade event (lightning bolts) a simple conversion of potential energy stored in every atom into kinetic energy is achieved.  In order to trigger an electron cascade event all that is needed is the proper pulse.  The best pulse would be in the ultraviolet light range and repeated at an interval determined by the resonance of your secondary.  The electrons slam into your anode and set the secondary into sloshing or oscillating "to and fro."  The secondary oscillations are then damped by the resistance of the secondary to drive the load.
  @Dom
     The Schuman resonance describes a piece of coax.  It can be used to transmit elf but it's parameters do not imply there is any large amounts of electromagnetic potential energy scources to be tapped at this frequency.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Zeitmaschine
If it did then the coil would dissipate 6.3kW of heat.
these equations are OK but incomplete.
Our whole electrical knowledge is based on magnetic induction (for AC current) - transformers, electric motors, etc, why we omit electrostatic induction. I think, this is a missing part of equations which is not used to this day.
It's time to use it. Some simple equations of mine:
1V on 1Ω = 1A, 1V × 1A = 1W, 78V on 78Ω = 1A, 1A × 78V = 78W, 78V × 9 = 702V, 702V on 78Ω = 9A, 702V × 9A = 6.318KW
As a logical consequence this coil does not dissipate 6.3KW of heat but rather is capable to collect 6.3KW of energy from the environment (ether). The question is, how? Perhaps 6.3KW of BEMF by electrostatic induction?
What we know:
a) The blue coil can't be the source of the 9 amps of current because (at least) of the missing back loop at the output.
b) The 78Ω coil of the transformer can't run 9 amps through it, hence the transformer coil itself must be the source of the 9 amps.
c) One pole of the output (to heater) is connected to ground (like the lamps in 2004 video).
Given the Kapanadze way of secrecy this is pretty much of knowledge so far.
Quote from: frantz on September 01, 2012, 08:18:21 AM
For me BEMF is some kind of magnetic resistance. Question is: for electrostatic have we this kind of resistance (maybe only ordinary resistance, which is negligible for small resistance and is independent from frequency)?
Help me to think, please. Maybe you will have better point of view.
What is magnetic resistance? A resistance of the ether? So BEMF is oscillation of the ether. Could there be a difference in the kind of BEMF whether it is a result of low voltage or of high voltage?
Quote from: Bernhard on August 14, 2012, 07:02:32 PM
I have this Kapanadze aquarium trans  8)
Could TK foresee this? No (because it is 30 years of age)? So he also couldn't foresee that everybody will know the transformers pin layout. That's a huge advantage.
The blue output cable goes to pin 1 of the 78Ω coil. What is connected to pin 2? Nothing? Or is it shorted with pin 1? Then could it be (lacking a better explanation) that this coil works as a capacitor plate only? The second plate would then be one of the other coils. 50Hz transformer and capacitor made out of one piece? Could this work? Or is this just one more Kapanadze »secret« that never will work?
If someone could provide a higher resolution photo of the area in the red circle, it would be much appreciated ...
Quote from: frantz on September 01, 2012, 03:21:48 AM
we must start thinking self. Not still analysing TK pictures...
Sorry, I can't let it be. :D
