0 Members and 182 Guests are viewing this topic.
a.king21
Wiring closeups.
Remember, TK offered, and we accepted a 3 phase 10 kw unit next. I think he was already preparing the aquarium 2 to become aquarium 3 phase. Just a hunch. So maybe the transformer is pre-wired for the next demonstration. Bearing that in mind, only one of the transformers is relevant to this build. TK has said in his patent that in order to get 3 phase he simply trebles his unit. So I would expect two of the transformers to have one wire  out at least. If we can locate that then we have a major find on our hands.
verpies
Quote from: Zeitmaschine on September 02, 2012, 07:30:16 PM
And is there not the saying don't apply logic and physics to the TK device?
Without logic and physics we migh as well be talking about religion.
Hence, what could happen if a high voltage (high frequency) spark hits not a coil or the windings of a transformer but the iron core of a transformer itself, or it hits the aluminum housing of a large capacitor? This illogical idea (that will surely never work) just crossed my mind.
Now this is just unconventional and not stupid at all.
It does not ignore physics but explores new territory.
For example there is an IEEE article by Konrad and Brudny that describes magnetic permeablility modulation of a core done by electric forces - HV electric discharge, I reckon.
McFreey's analysis should not be ignored either.  It relies on sound physical foundations and one weakly documented phenomenon, namely the stimulation of beta decay by NMR. It is relevant to the Yoke device, too.
The remaining phenomena, such as the influence of magnetic field on the products of the beta-decay in solid matter is well documeted already.
For example see this illustration, which is applicable to high-speed beta-decay electrons, too:
(there are more interesting illustrations at this link)
verpies
Quote from: a.king21 on September 02, 2012, 10:43:44 PM
Relying on theory doesn't work.  History has proved that a lot of theories are ultimately wrong. They become superceded by better theories.
Pure esoteric string thories maybe, but not empirical engineering principles.
Your computer would not work now if hundreds of them were not true.
For example 10A of electric current going through a 100Ω resistance will dissipate 10kW of heat in that resistance (P=I2R)
Calling the above equation a theory and ignoring it will lead you nowhere.
By the same token it is common sense to reject the possibility that a 70Ω winding with 9A flowing through it can withstand 5670W of heat flow in a small transformer.
Ignoring empirically established laws of physics and engineering principles will not lead to reality.
verpies
Quote from: a.king21 on September 02, 2012, 10:27:18 PM
Done the experiment. lol
You get resonance between L1 and L2.
How did that resonance manifest itself?:
What and where was the stimulus applied?
What was the element exhibiting an energy storage (a prerequisite of any resonance)?
What was the amplitude and frequency of this resonance?
verpies
Quote from: a.king21 on September 02, 2012, 08:05:23 PM
The wires to the heater are HV. The braid is a HF/HV shield.
Conclusion: His secret somehow generates HV, whilst using mains 50 Hz 220 volts.
This is not the only conclusion possible.
However if this conclusion is correct, then it should not be ignored that HV low current cannot create heat in a resistive heater, and that would mean that there is a voltage/current converter inside of the heater or the heater has another route of power supply.
