0 Members and 147 Guests are viewing this topic.
balphom
from Dom Tesla
The main curcuit has to have a resonance frequency of 7,83 Hz. The load is grounded, and connected to the maincurcuit. The earth then resonates to the curcuit and high frequency resonance currents develope.  . The load is the Puller of higherdimensional/Ether energy wich manifests as current. The higher the voltage of the maincurcuit the more electron pull is possible in the same time.
you seem to have some valuable information is your resonance frequency missing something because of where you placed the comma.
According to the videos we have i can connect to the information you have
captainkt
@verpies, Hi just a note about hitting trans core with HV, last night I did this by accident and the iron core was sparking to one of the windings, suddenly the complete transformer (3 phase) went wild everything on the bench was sparking and buzzing I quickly got a 100 watt bulb and touched it on some of the nine wires coming out and it was full bright on almost any pair. The core of transformer was to earth and somehow this got disconnected and I think the very large transformer acted as a choke for the HV (about 3000V). My work bench is one big mess with a mixture of experiments so now I need to look in more detail at what happened. the bulb on transformer did not increase the current draw on main circuit 5A about 1.5 kw load.
Keith
verpies
Quote from: captainkt on September 03, 2012, 07:36:41 AM
Keith
Strange, the effect described by Konrad and Brudny in that IEEE article would have lasted only for the duration of the spark discharge.
However, if the transformer permanently shorted out internally due to this short spark discharge then maybe you had inadvertently created a permanent Multiplication Ring inside the transformer, as described by McFreey.
captainkt
@verpies, never thought of that, interesting that the transformer has thick copper strip as one set of windings (outer and visible) and 4mm multi strand wire for the other with a smaller winding of 2mm solid wire. so three wires from each core. Trans size is 12inches by 8inches by 4inches in old money, with three sets of coils. Could be from a welder.
Keith
