0 Members and 180 Guests are viewing this topic.
DilJalaay
Hello All,
Here i found the latest videos of "Don Smith Inventors Weekend 2005 DVD1 and DVD2".
It looks T.K doing the similar work with very little difference.
http://www.youtube.com/playlist?list=PLE936468280B4BEED&feature=edit_ok
Hope you enjoy all the best and regards,
D.J
yfree
Quote from: a.king21 on September 02, 2012, 08:05:23 PM
Something to consider: The output spark gap is HV. The wires to the Spark plugs are HV. The wires to the heater are HV.
The braid is a HF/HV shield.
Conclusion: His secret somehow generates HV, whilst using mains 50 Hz 220 volts.
The centre of his blue output coil pack is shielded with what appears to be polystyrene.
Resistive loads like bulbs and heaters can be supplied with high voltage, high current pulses and work properly, as long as V*I*F (F - duty cycle or fill factor) is around their power rating. TK devices inherently produce high voltage pulses as they rely on fast avalanche, extremely high current (hundreds to thousands of A) phenomena. To reduce these voltage spikes on the load he uses the visible coil connected between the output of the black box and the load and the spark gap arrestor to make sure that the input to the load is not sparking. The output of the device is still high voltage and pulsed although not as high as the output of the black box. This is why the visible coil is wound with a well insulated wire. The internal electronics of the device cannot use this HV pulsed output, therefore a transformer is employed to lower the voltage as described here or there.
sparks
Quote from: yfree on September 03, 2012, 10:37:36 AM
The energy of the inidividual electrons ionized from a gas is totally dependent on the wavelength of the pulse and independent of the amplitude or intensity.  Tesla also describes how very high voltage and very short pulses renders the natural medium conductive.  Of course it is conductive because plasma has very high amounts of free electrons whereas in oxygen and nitrogen the electrons are bound.  The magnifying transmitter was going to pull it's power from ionization of the air on his plates.  This electron avalance gain in his top capacitor plate would as I described earlier send his secondary into resonance which then would be transmitted via one-wire using Earth as the wire.  Bohr's classical atomic structure was never refuted but modified to assign electrons different signs due to the Pauli exclusion principal.  The Pauli exclusion principal was developed due to the ultravioloet light catastrophy.  The uv catastrophy simply was catastrophic because of the theoretical physicists not admitting that space was alive.  They described space as a perfect blackbody radiator and therefore had no preference as to what frequencies it would store or what frequencies it would be transparent to.  If there was fluctutaions of the vacuum itself it meant it was an unlimited scource of energy/change and the bigbang theory was dead.  Recent observations of cosmic infrared background radiation have been hampered due to the large amount of cosmic infrared foreground scources.  The cosmologists using infrared astronmical sattelites have found vast clouds of dust.  They then turn around and say that this dust is very cold and heated by starlight.  How can something that glows in the infrared bands be cold.  I remember touching the glowing metal element of an electric stove top and discovered at the age of 3 that things that glow are not cold.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
yfree
Quote from: sparks on September 03, 2012, 02:25:14 PM
You have to be more specific, because no matter how I look at this, I do not see any connection between my quoted post,  #13708,  and your replay.
verpies
Power dissipated in a resistive load that is supplied with a pulsed current: P=R*(I*F)2
