0 Members and 560 Guests are viewing this topic.
baroutologos
I was reviewing SR's first video http://www..com/watch?v=18oThcI4VnE&feature=player_embedded
concerning the below coil setup and its accompanied schematic.
The running equipment is quite obscure, and this PVC pipe does not seem to have any core. (it may have inside). I wonder what the special has this schematic?
Two coils counterwound, yet oppositely connected resembling a biffilar coil parallel connected. The third coil is seemed out of inductive action (from the 3-ring coil) but in parallel with the bulb. The third coil possess an opposing polarity to first coil, thus resembling a special center tap transformer.
All three coils can be regarded as 3 parallel windings in their net effect.
In case it had a slide-in core, it would remind me Tesla's regulator method patent, thus adjusting bulb's brightness...
Nevetheless, anyone with any idea for its usefulness or its just fancy coiling and for theorizing food ?
baroutologos
In continuation to study the "SR" effect, i undertook a series of experiments.
The main idea was to make a ferrite core transformer work as... tranformer and the same time a set of high frequencies to be injected to the system by a working spark-gap. (no caps involved)
The schematics i found them in lab101 russian forum. (see below) and http://www.konvenat.ru/content/view/126/34/lang,russian/ (see the large photo)
I have read somewhere that the SR admin and alleged replicator said that 80% of working principle of Kapanadze devices can be seen at the 100Kw video.
Experimental setup
I connected 10 ferrites cores so as to form a hollow long rod of 12cm approx.without letting any spacing between them. Then i fasten them into place with hard papaer and tape.
I wound:
winding a)  30-40 turns solo layer of 0.75mm speaker cable along the core
winding b) Like wise above the winding A. This is slighter larger in diameter and have a inductunce of 140uH
winding c) 8 turns of 1.5mm speaker cable for connecting to the load. (lamp)
between windings a layer of 0.35mm Mylar is added (6KV resistance)
The plan was to connect to a plain spark-gap the first winding thus filling the core with high frequencies. The second winding is to be connected to a highly charged capacitor thus acting as a normal "tesla transformer" loading with alternating magnetic flux the core.
Third winding the bulb (20 watts, 12volt)
I connected several cap values for the oscillating LC part of the circuit (50nF, 125nf, 250nf, 2.4uf and 4.8uf) The larger caps are unsuitable for my little ignition coil HV power supply.
The spark-gap was connected to my Kacher that i must admit it runned at low power (due to problems). In one side of the transformer all windings were connected to a good ground.
This approach failed to give any appreciable results or even a hint that something is going on there. (at least with those materials, given dimensions and power levels)
Next thing i am gonna try is the inverter apprach or the coil pulse approach (inverter style) but with a winding of a working spark-gap. (My spark gap is not a solo diode rather a FWBR, in case it matters)
xenomorphlabs
@baroutologos:
So what did you exactly send through the 2nd winding then?
At what frequency?
The wire running through the core with the HV pulses could as well
be just running straight through it rather than coiled.
That way it would not interfere with the actual 2nd and 3rd winding coupling.
What colour does your spark have?
No matter what i do, my arcs are always white.
Keep it up
baroutologos
Hello Xeno,
Yes you have a good point there. Next thing i am gonna increase the Kacher's power and put a wire to go through coil's core or with a minimum winding.
The LC resonance frequency varied as varied the discharging caps. the 125nf cap give some 38Khz.
We see but i have not great hopes on this
ps: My sparks are always violet
xenomorphlabs
I have actually tried to pulse the earth ground wire with the spark gap
using the natural potential difference between the HV out of the transformer
and the earth. That would only produce white sparks. (Surprising that it works actually hehe)
If i hook up the other end of the transformer to the corresponding side of the spark gap, then the arc becomes violet.
It is a bit difficult to understand for me, what purpose the earth ground connection from the closed circuit which is formed by the HV transformer secondary through the spark gap is supposed to achieve.
I can imagine it will guide the scalar wave created by the spark,
but i am not sure if there is an actual electric current between the earth and the spark gap (just regarded without the whole inverter issue).
If one looks at it like 3 different potentials then i guess there is current (with earth being zero potential).
Maybe i am wrong?
