0 Members and 105 Guests are viewing this topic.
verpies
Quote from: wattsup on September 04, 2012, 10:09:55 PM
There is no hidden wire in the shielding coming from the cement slab. There is only one connection on that bolt, not two or three. There is also no connection inside a hidden connection. Only one connection.
How can you be sure based on a video evidence?
I can make a concealed double connection on a bolt using coaxial construction and two stacked washers divided by a thin insulator film...and it would be well hidden from human eyes too, if one did not know what to look for.
verpies
While the device was running, the big guy lifted up the device and the shielding was hanging down onto his fingers. If it was HV spiked on that line, he should have said something, like Ouch, then dropped the device.
No, a simple insulation (even enamel) can prevent a shock.
Also, 1-sided touch to the grounded side of a 3kV circuit will not produce any sensation either.
captainkt
@farmhand,The device on the tyres was also taken to TKs house and a video made on glass table to show no batteries.Also regarding batteries I ran 100watt bulb with fully charged car battery and inverter, runs for a very short period before battery dies.
Keith
Hoppy
Quote from: verpies on September 05, 2012, 01:41:29 AM
Although I agree that its quite easy to make a double connection as you describe, IMO its more likely that the inner conductor(s) were taken out of the braiding somewhere near the window. A good high res photo of the braid as it travels up and through the window from inside and outside of the room may have revealed something. I assume the the investigating team did not take shots covering the complete length of the braid, otherwise they would have already been posted. A magician is always a few steps ahead of his audience and does not expect the analytical eye of the audience to wander too far away from the candy.
The NMR, although an exciting possibility, hardly warrants the description - 'laughably simple', so it really is necessary to completely eliminate any trickery.  This can only be done with a another demo where the emphasis is on investigating everything outside the box thoroughly. For example, the unit should be turned-off and the 'earth' lug removed from the rod for inspection and every inch of the braid checked and photographed.  Also, as has already been suggested, the outside of the surfaces of the aquarium and the heater should be examined in detail and measurements taken. Any objection to this by TK should be taken as admission of fakery. Without this level of detailed investigation, no conclusion can possibly be reached over the validity of the TK  device.
Hoppy
captainkt
@Hoppy, why think the braid is trickery when the green box vid did not use any braid it used a really heavy earth wire wound round a water pipe, and it could be clearly seen only one connection 100%. I have watched it many times and no way was there any other feed to device. Most interesting was the inverter was used in between looping, and then battery removed. I assume doubters think in other demos this start battery is hidden? In fact I think TK just got cleverer and now uses small 9volt for starting by improving circuit.And in doing so could say look no batteries.
Keith
