Hoppy
Quote from: captainkt on September 05, 2012, 06:29:28 AM
@Hoppy, why think the braid is trickery when the green box vid did not use any braid it used a really heavy earth wire wound round a water pipe, and it could be clearly seen only one connection 100%. I have watched it many times and no way was there any other feed to device. Most interesting was the inverter was used in between looping, and then battery removed. I assume doubters think in other demos this start battery is hidden? In fact I think TK just got cleverer and now uses small 9volt for starting by improving circuit.And in doing so could say look no batteries.
Keith
The green box vid could have been faked in a different way, so simply saying that the aq2 vid braid has to be a single conductor just because the green box earth wire was a single conductor does not follow in my book. We will all continue to go round in circles arguing fake v genuine until and if an in depth analysis can be carried out on a working TK device, which seems to be very unlikely. I'm not saying that the braid is trickery, just that its quite possible that it concealed energy carrying conductor(s).
Hoppy
verpies
Quote from: Hoppy on September 05, 2012, 04:33:10 AM
It really is necessary to completely eliminate any trickery.  This can only be done with a another demo where the emphasis is on investigating everything outside the box thoroughly.
Yes, why don't we all pitch in and eliminate it once and for all.
Let him build an opaque contraption/ustroistvo with DC output for us, but this time around we will not investigate the inside of this box.
It costs only $500 to travel to Tibilisi from eastern Europe.
stprue
Quote from: verpies on September 04, 2012, 06:29:50 PM
Near field induction is sensitive to the orientation of the coil - the coil in the demo is not.
It is much more likely that there is a battery in the motor or in the glue holding the magnet, than a power transfer by near field induction.
You're right! This seems more plausible.
Hoppy
Quote from: verpies on September 05, 2012, 07:37:00 AM
The first step would be spell out exactly what the investigating team wish to do using a written test schedule, with the condition that no money changes hand (other than perhaps a small deposit) until the investigation is complete and carried out in accordance with the schedule. Chances are that this proposal would turned down flat but no harm in testing the waters.
Hoppy
wattsup
Quote from: verpies on September 05, 2012, 01:43:24 AM
No, a simple insulation (even enamel) can prevent a shock.
Also, 1-sided touch to the grounded side of a 3kV circuit will not produce any sensation either.
@verpies
The question is not if this was a real ground with 3kv+ on the other side, the question is if the ground lead carried the HV+. If it did carry the HV+ then his fingers should have received a good shock. But he lifted it and held there as if nothing occurred.
@all
Question for the top EEers on the forum.
In the Green Box and 2004 videos, we see the black heat sinks with just two wires going to each. ONLY TWO, not three.
If those heat sinks held Zenor diodes and each diode was used in a way to pulse the primary of a flyback, hence you would have two flybacks, one per zenor diode, and you also had only one capacitor as the accumulating source from which the Zenors would pulse, how would you go about choosing the zenor diode and making the circuit diagram? I know there are zenors that have the mosfet topology.
Is that possible?
Then there is another funny thing going on.
In the 2004 video, I was looking for any wire or anything weird at the center wind area of the 6 turn fat copper coil. Like a center tap. This because according to my theory, it would call for such a connection.
Anyways, at 13:21 when TKs helper handled the step down transformer thus moving it, you can see the 6 turn coil moved as he first lifted the transformer. The transformer has a bolted diode plate and that plate was put back to contact the center point of the 6 turn. He shorted the 6 turn center point with the diode plate. Coincidence?
Also on the far end of the 6 turns (actually 5 1/2 turns) you see a HV type wire coming from the tin can to feed that side of the 6 turn. You also see another wire coming from the tin can to feed the left side of the spark. Now if those two wire were HV+ coming from two small flybacks, then you would need a negative at the center tap area of the 6 turn. hehehe
This also equals the Wesley Georgia video three connections to the 6 turn and also the 2012 video Coily Coils getting HV+ from two side so there must be a center tap there as well as I had mentioned going to the center coil and then we see it go to ground.
Also, about the Wesley Georgia video off CDI, the PINK and WHITE wires of the battery start go to the CDI. hehe Does anyone have a real data sheet with color id on the CDI of Wesleys video. Urgent.
wattsup
PS: More pieces are coming together faster and faster and the devices are starting to coalesce with their "mutualities".
