Hoppy
Quote from: wattsup on September 05, 2012, 09:25:04 AM
@verpies
The question is not if this was a real ground with 3kv+ on the other side, the question is if the ground lead carried the HV+. If it did carry the HV+ then his fingers should have received a good shock. But he lifted it and held there as if nothing occurred.
Just to chip in on this one, it would pretty stupid to put 3KV down the braid, given that the braid is lying all over the floor and highly unlikely given that there are photos of hands all over it! As to whether there is an inner conductor carrying HV or grid mains, then I see this as a valid question.
Hoppy
captainkt
@Wattsup@Hoppy, If braid is 3KV + only get shock if earth disconnects at the earth connection. When I was younger messing about in my shed I wired up a one bar 240volt electric fire the type with open tungsten windings, I would put a metal bar to negative and drag bar along towards positive and see at what point I would get a shock usually started to tingle about half way.
Keith
verpies
@verpies
I disagree.
Polarity has no influence on the safety of LF galvanically isolated circuits.
Touching one side of such circuit does not complete it hence no current flow and no sensation is elicited in the human skin.
Hoppy
Quote from: captainkt on September 05, 2012, 10:57:49 AM
Keith
OK, if the braid is carrying 3KV then where is the earth wire in TK's aqua2 device?
Hoppy
verpies
Quote from: Hoppy on September 05, 2012, 08:52:54 AM
The first step would be spell out exactly what the investigating team wish to do using a written test schedule, with the condition that no money changes hand (other than perhaps a small deposit) until the investigation is complete and carried out in accordance with the schedule. Chances are that this proposal would turned down flat but no harm in testing the waters.
I would envision sth simple like this:
Dear Tariel:
1) Build the smallest and lightest opaque "black box" with 230VDC output and as high current as you can.
2) Allow us to touch and measure everything except the internals of the box. That is:
    a) the outside size of the box
    b) the weight of the box
    c) the space around the box including any wires protruding out of the box
    d) our own resistive load connected to the box (supplied with Direct Current (DC), by the box)
The simpler - the better.  Help me refine it if you feel like it.
