0 Members and 355 Guests are viewing this topic.
Farmhand
Quote from: captainkt on September 05, 2012, 06:29:28 AM
@Hoppy, why think the braid is trickery when the green box vid did not use any braid it used a really heavy earth wire wound round a water pipe, and it could be clearly seen only one connection 100%. I have watched it many times and no way was there any other feed to device. Most interesting was the inverter was used in between looping, and then battery removed. I assume doubters think in other demos this start battery is hidden? In fact I think TK just got cleverer and now uses small 9volt for starting by improving circuit.And in doing so could say look no batteries.
Keith
Quote1. Firstly the neutral wire of the mains is connected to the water tap/water pipe for one ground wire. ( the tap wire )
2. Secondly an active wire from the mains is previously buried in the garden below where the radiator is to be buried
maybe connected to a conductive plate. The radiator wire.
3. When the radiator is watered in  well a low resistance path is created between the buried wire and the radiator with the wire
connected to it.
4. Take both wires to the demonstration bench and connect them with an assistant observing from the flat/house.
5. On a given signal the assistant flips the switch to energize the radiator which powers the lights however is desired.
6. The battery shown could be recharged by the mains while doing it.
The garden video could maybe be faked how i described back in August.
Cheers
Zeitmaschine
A bundle of quotes:
Quote from: cosmoLV on February 15, 2012, 02:03:27 PM
Also output transformer is not transformer but choke where High voltage are producing light ionisation second "inductor" produces light magnetic field who is produced by (sparkgap) No more than 2000 triggered volts in frequency of 50 Hz (or by your choice, for example 60Hz) By increasing frequency of sparkgap, or "can be replaced" with electronic sparkgap like (SIDAC), can be achieved different types and characteristics of magnetic field â€" Up to gravity effects (something about "one million interrupts per second")
Quote from: cosmoLV on October 07, 2010, 10:54:33 PM
by the way on my repply above.. Mr. Tiger from "001-lab" was very close, very close
Quote from: Shokac on October 20, 2010, 09:53:42 AM
Cosmo, do you think the first or second picture?
Quote from: cosmoLV on October 20, 2010, 11:23:52 AM
No, i mean this: it need a little bit polishing ;) why Tiger are stop on that i do not know, but it is close
It is close? Even very close? Because the spark hits the core of a coil in that picture? Yes, this could be very close ... well ... at least interesting!
Now the little polishing: (If) the core that is hit by the spark is that of a choke connected between 50Hz source (inverter) and the load (lamps), then the question: What core material is best to experiment with? Iron? Ferrite? Brass? Copper? Aluminum? etc.?
Just asking. :)
Quote from: a.king21 on August 20, 2012, 07:12:22 PM
Anyway Tariel makes his mistake. He shows us a section of it. It looks like it's made of copper.
That would explain his metal working equipment.
In discussions with me he always said that he would have to make one component himself.
That is the secret.
Is that so ...
yfree
These excerpts are from "Steven Mark's Torroidal Power Unit" v2.0/2007
I hope things are calmed in your life when you receive this.
I fully understand your feelings of frustration.
To work hard to see nothing of a positive is sometimes shattering to one's
self.
I know very well...
I had a great deal of help and it took us years just to develop a SS control
system that would work!
And this is after we knew how to make generators!!!
Speed is energy if you can convert the mass into energy quickly
enough!
Anything no matter how small can store enough energy to convert
into huge amounts of energy.
Even electrons.....................................
Now, electrons can travel only so fast along the surface of the wire
because of magnetic flux.
What if you disable the effects of the flux?
My unit operates on these principles.
Now the electrons float freely without anything holding them back.
Electrons at the sped of light are now a possibility!
How much energy can be converted from a stream of electrons traveling
close to the speed of light?
They also have no concept of how important the control
frequencies are in order to make power from the collector.
I assumed that anyone working on technology this sophisticated would
have a superior knowledge of electronics and an understanding of PURE
frequency output being a Necessity to control the reactions going
on inside the collector.
Sincerely,
SM
verpies
That is the secret.
Maybe that's the copper beta-avalanche current multiplication disk/ring, as described by McFreey.
Which photo were you referring to when you wrote the above?
verpies
Quote from: 27Bubba on September 05, 2012, 04:49:11 PM
"Dear Tariel:
1) Provide us with all the necessary parts needed to build the device (assembly kit)
2) Then let us figure out how to connect these parts the right way to make it work"
Would love to hear his reply! :D ;)
I think Wesley proposed sth very similar to him and even arranged a 7-figure investor.
TK was vacilating too long and did not meet the investor's deadline.
You could probably get more details out of the horse's mouth.
