0 Members and 35 Guests are viewing this topic.
Zeitmaschine
Quote from: verpies on September 05, 2012, 06:46:15 PM
Maybe that's the copper beta-avalanche current multiplication disk/ring, as described by McFreey.
Then hit the copper disk/ring with the spark, not the surrounding coil as suggested by McFreey. Could be that helps.
yfree
Quote from: Zeitmaschine on September 05, 2012, 07:20:06 PM
The idea is not bad at all. Only, the energy of electrons accelerated in the spark is not high enough to invoke the necessary reactions. It may also be difficult to inject the electrons from the spark to where they are needed.
Jack Noskills
Quote from: verpies on September 05, 2012, 01:43:24 AM
No, a simple insulation (even enamel) can prevent a shock.
Also, 1-sided touch to the grounded side of a 3kV circuit will not produce any sensation either.
I got shocks from coil made from Mylar C insulated wire. Input signal was 220V/50 Hz, 400 meter coil around 80000 perm core. More power I put through the winding bigger the shock. Can you get shocks from electric field or was it dielectric field that was biting me ?
captainkt
@farmhand, the green box gen only uses one earth, first attempt with radiator not good enough earth- so wire was changed to water pipe. Water pipe was checked first to show no voltage. Then wire connected and twisted tight for good connection. Only one wire goes to gen not two so where is the circuit to fake, then all is lifted up to show only one wire.
Keith
verpies
Quote from: Jack Noskills on September 06, 2012, 01:13:42 AM
If the coil was pulsed (AC or PDC) then, when the coils's circuit opened or its current changed (as in AC), the induced voltage exceeded the wire's insulation breakdown point.
Coils "want" to keep the current through its windings constant "at all cost" - even if it means developing 100kV across its windings.
