0 Members and 168 Guests are viewing this topic.
wattsup
Quote from: Zeitmaschine on September 09, 2012, 10:10:45 AM
It could be that Kapanadze doesn't care about the coil is touched by something because he knows that this coil has nothing to do with the production of free electric energy. It would be rather strange if TK counts on a random connection with the diode plate in order to keep the device working.
What is so random in having a diode plate connect to the 6 turn, move the transformer to show it moves the 6 turn, then put the transformer back where the diode plates touches again the 6 turn. There is nothing random there but the ramifications of this are immense, notably to provide the 50hz timing to the output.
This means I need a step down transformer and work off the mains to do the same thing with my set-up because up till now there is something missing. HV pulses on the 6 turn will not do the job. There is just not enough energy produced to create the effect which must happen at a minimal critical point. The resonant point seems to be between 10kHz and 24kHz which is the area of best workable range for flybacks.
We cannot dispute the Aq2v. It is so open and load is well segregated from outputs. There is only the tapped output to the heater plug that could hide at best one small capacitor and a connection method using the four conductors.
@all
I have to go to Paris for a week starting Monday so I will be off my work bench but till then I will try more angles and if there is anything really worth showing, I will do another youtube.
I really feel like this thread is becoming a dumping ground with so much irrelevant posts. I would suggest that when you post something, tell us why you think the post is relevant to the TK device.
It could be any crazy idea, as long as it is relevant to TK devices, but you need to tell us why you are posting it and not just dump so much on the thread and leave us to ponder the relevance and waste time.
Case in point: Is it possible that the TKc has some internal hidden cores that are not in the center of the pipe they use to wind the coil as this would be easy for observers to see. See diagram below of possible ways to hide a core.
All we can see is the outer winds of the TKc. But this leaves so many places where the wind can be cut, then directly enter the center area and we would never know it.
Also, a question to @a.king21, can you tell me if your observer friends that were at the demo happened to look straight into the pipe opening of the TKc, and if so, what did they see if anything at all??????????
wattsup
Hoppy
Quote from: wattsup on September 09, 2012, 12:00:35 PM
wattsup
Are you able to draw up a circuit block schematic of what you have deduced so far from your video analysis and from this postulate on the nature of the power source to run the aqua2 heater?
Hoppy
wattsup
Quote from: Hoppy on September 09, 2012, 12:26:14 PM
Are you able to draw up a circuit block schematic of what you have deduced so far from your video analysis and from this the nature of the power source to run the aqua2 heater?
Hoppy
@Happy
No, not yet but I am not far away from that. I will try some more experiments today adding a Variac and send one line to the center of the 6 turn coil, to see the effects. TK says it is so simple. HV pulse of a coil with a center tap high amps AC bias fits into the simple category. Much simpler then NMR theory.
wattsup
Zeitmaschine
OK, I think this is relevant to TK device because it has 50Hz transformers, diode bridges and capacitors, and it can do something that was worth to patent it (maybe).
http://www.freepatentsonline.com/EP2387142.html
But I'm quite not sure what it could do. ???
Placing a diode in the primary circuit of a transformer would mean to lose half of the input power, wouldn't it?
Or did I miss something with respect to physical laws? ???
