Zeitmaschine
Quote from: frantz on September 12, 2012, 06:40:51 AM
author spoke in first movie about problems with polar caps. He used non polar to device.
Maybe the problem with polar caps is the high power batteries do not fit in? ::)
Use conventional caps connected in this way (in series):
+ 10µF - - 10µF +
This should result in 5µF non polar (bipolar).
Hoppy
Quote from: frantz on September 12, 2012, 07:04:05 AM
Hoopy,
this caps have a several uF (8 or 10), only size of this caps are large. Capacitance is relatively small...
Give him a some time to publish data...
I know that everyone are impatient and waiting too long time but we must wait a little yet...
No problem waiting for the data, as long as he does a more realistic demo as well.
Hoopy  :)
verpies
Quote from: TheCell on September 11, 2012, 04:03:47 PM
@T-1000
NMR ?! He uses no ferrit core. Where should it happen ?
Good question. If a cylinder/ring/disk of solid material (e.g. ferrite) is not used, then the McFreey's operational principle cannot apply.
As for as NMR - it can happen even in air, wood or plastic, or wires (or meat), however NMR alone cannot create an avalanche of electrons and the resulting high current pulse.
Devices based on the McFreey's operating principle must have a confining mechanism (magnetic field) and "electron lasing medium" and I don't think air would make a good one.
Seems like a block of ferrite or brass or other solid (even thick wire) is needed as a dense "electron lasing medium".
verpies
Quote from: frantz on September 12, 2012, 01:56:16 AM
Guys, what are you talk about?
Let read Russian forum. If you don't understand in Russian language, let use Google translator...
Google translator does not produce technically accurate translations, and does not translate the text on the bitmap diagrams at all.
People who do not know the Russian language cannot benefit from the Russian forums.
They are at the mercy of native Russian speakers to summarize and post English diagrams and text here or other english forums.
4q
Small notes for actual Dally's generator:
He uses nanosecond pulses "kicks" applied to a load which is an closed transmission line.
Please remember SM and TPU's transmission line and kicks, Tesla's bifilar coil, Prentice's patent, Hendershot's capacitors and the NOTHING IS SOMETHING by Floyd Sweet. They ar all uses Transmission Lines!
Floyd Sweet states: "Since any
capacitor behaves similarly to a transmission line it is no more necessary to postulate a
displacement current for the capacitor than it is necessary to do so for a transmission line."
The pulses time about 3.5-5ns. The speed travels in a 1 meter of RG58A/U coax cable  about 5ns which is near equals to the pulsing time. All of energy applied to the input terminal of the end closed coax cable dissipates on the insulator and the ohmic components of the coax thus the input impedance remains almost imaginary. It means very-very huge imaginary energy circulates in that coax cable. Seems that TK needs coaxial cable to the device to operate it.
Longer TL needs longer kick's, so maybe at Prentice's patent the sparking would be enough to create the necessary pulses.
Just analizing the Prentice's patent, Dally's generator, Hendershot and TK devices which is my favorite one well shown the principle of operation of these type of FE devices:
1.) Pulsing a transmission line which has closed at the other end (or terminated: remains imaginary but the high voltage may penetrate the center insulator). It seems that the important thing here to that the pulse width should be equal to the transmission line's speed velocity or can be comparable.
2.) Apply a second frequency around this line via a coil, or in Prentice's patent: direct to the opened TL.
3.) Use a parallel resonant LC tank around that maximize the amplitudes. I think this is resonant at the second generator's frequency or upper harmonics.
4.) Output coil / antenna around that will collect more energy which was applied by the pulses and the second generator's input.
5.) Need and earth connection.
These are enough "simple to laugh" but need to b accurately calibrate. I don't know how the imaginary energy converted to a real one and why needs an earth connection but these factors above are necessary to achieve that. I know these are above just contemplation but somebody needs to be see the similarity between the past devices and the current ones and I tried to collect the common operation parameters.
Thank you guys, sorry for that long post.
