0 Members and 299 Guests are viewing this topic.
Hoppy
Quote from: Ganzha on September 12, 2012, 01:45:17 PM
here is video of Dally device http://youtu.be/6Hjv3-hBZ2o
there are  some suspicious sreen shots
This guy clearly wants viewers to think his demo is faked, so maybe its not  :-\
Hoppy
T-1000
Quote from: verpies on September 12, 2012, 07:58:43 AM
Google translator does not produce technically accurate translations, and does not translate the text on the bitmap diagrams at all.
People who do not know the Russian language cannot benefit from the Russian forums.
They are at the mercy of native Russian speakers to summarize and post English diagrams and text here or other english forums.
Wesley already tried to translate - http://www.youtube.com/watch?v=amZxIpg5nP4#t=0h16m2s
My comment on this:
As far as I see the second generator with coax cable winded on selenoid is between primary and output coil and there is resonant ballast LC coil is between coax and primary. The coax cable function seems to be disruption of main tarnsformer energy transfer from primary to output what got LC resonant ballast coil of ~4.6kHz in middle of those 2 coils. The coax cable is shorted on one end and nanosecond sawtooth pulses ~1khz are fed into its another end. That makes short living standing wave between primary and output coil. Everything else should be checked experimentally.
To test in short: wind primary on air core selenoid->wind resonant ballast LC coil in middle of selenoid->wind coax->wind secondary to output. Then feed main frequency into primary->resonate LC coil->connect load->see conventional transformer energy transfer->feed HV sawtooth impulses of 1/4 frequency and duty cycle <10%(spark gap peak waveform) into coax cable for standing wave pulses->loop back output into input->see if you can self run device. Avoid multilayer windings, test with single layer coils first.
Woopy, Itsu and a.king, this is a job for you TODO ASAP :)
Cheers!
P.S> Wesley, please keep Skype on so we can catch up on some point.
stivep
Quote from: T-1000 on September 12, 2012, 06:09:15 PM
My comment on this:
Cheers!
Ok I will.
I have had so much problem with bandwidth I disconnected Internet while editing video.
new link for replacement video is
http://www.youtube.com/watch?v=QHBEHOOsxT4&feature=youtu.be
Please understand very much private nature of this video
It is still being loaded.
That will replace  first one.
This video is more memory of 9/11 as I was with my  scientific entity at 77 floor of WTC1
So I was scheduled to die.
And I did not...
Pretty straight  comments about dustification of towers.
Also transition from me being the  designer of ultimate killing machine, literally ( not a joke) to quite opposite creature.
(The gun that shots without sniper next to it in the center of the  pin placed at the center of the dime that was placed 150 feet away ( and dime is in motion)
What the stupidity...
I thought that ultimate killing machine from both sides (of enemy) will prevent killing.That explains why I'm who I'm  now.
How did I get into it?
Well I was Principal Investigator and chief of scientific team in program "Active Mine Detection."  *(DARPA )  much before that...( Yugoslavia-Kosovo time) I presented for Army Rangers in Colombus Georgia,also  Geophysical Bomb concept ( for underground imaging - not for killing)
Information about recent OU.
Next video published shortly will be more accurate
Wesley
Zeitmaschine
Quote from: FreeEnergyInfo on September 12, 2012, 03:57:06 PM
DALLY SCHEMATIC ....
This is not Kapanadze device. TK device has 50Hz output (in green box video). What could this mean?
Is it partially Kapanadze? Then which part? The coax cable perhaps? What happens if a coax cable is pulsed with high voltage next to a 50Hz cable? Or the center of the coax is 50Hz circuit and the shielding of the coax is pulsed with high voltage?
What is the difference between the capacity created by a coax cable and the capacity created by a bifilar cable?
What happens if L2 is removed? Free Energy gone?
What if L4 is dimensioned for 12V output instead of 220V? Could a direct 12V feedback work without the ATX?
BTW: The switch in the upper right corner is drawn at the wrong place in this diagram. Is should be between the capacitors and the lamp.
Quote from: Jon_sparky on September 12, 2012, 06:23:45 PM
Thanks for mentioning this! In the light of announcements: "release of technologies to all scientists on Sept 21"
it is One to watch:
So the time of travel to visit Kapanadze will be about 10 minutes maximum. :P
