frantz
Quote from: Ganzha on September 13, 2012, 04:27:28 AM
Ð"а просÑ,о гениальный способ получения (сравниÑ,ельно чесÑ,ный)излишков денег оÑ, сÑ,раждущи Ñ...алявы!
СÑ...ема просÑ,а
ОÑ,крываем сайÑ,ик бесплаÑ,но
собираем доску с Ñ,,эйком
поÑ,крываем счеÑ, веб моней
симаем муÑ,но Ñ,,эйк
начинаем переписку
Ð"оворим чÑ,о осцилл полеÑ,ел в резульÑ,аÑ,е доводки
ПросяÑ, сÑ...ему
оÑ,вечаем чÑ,о Ñ,,аллическую каÑ,уÑ...у  "баÑ,она"  намоÑ,али на чем Ñ,о
не помним на чем и непони каким проводом и случайно
шибануло Ñ,оком
продолжаем демонсÑ,рироваÑ,ÑŒ Ñ,уÑ...лое видео
не всÑ,речаемся ни с кем в своем регионе чÑ,обы не спалиÑ,ÑŒ Ñ,,эйк
собираем деньги кормим наро нерабочей сÑ...емой напичканой условно рабочими блоками
ведем переписку
Ð"ружим с Wesley
собираем деньги
исчезаем с веб монями ...
ТраÑ,им  пожерÑ,вования лоÑ...ов
Спасибо вам за вашу чесÑ,носÑ,ÑŒ
sparks
Quote from: verpies on September 12, 2012, 12:03:26 PM
But this process downgrades or destroys the photon, see Compton Scattering or Photoelectric Effect.
This only an energy conversion (from the photon to electron), soon the downgraded photons cannot eject electrons from the atoms anymore...unless the supply of fresh photons is maintained.
But the power supply connected to the anode must expend energy to do that. If not then the electric potential of the anode becomes quickly neutralized by the incoming electronic charges.
Yes, but only at the expense of the electric potential between the anode and cathode, hence no excess of energy remains in the system.
But building those lighting leaders costs the cloud energy.
   All of the above losses mentioned are avoided if the electric field established between electrodes (acting as capacitor plates) is pulsed.  The higher the voltage and the shorter the duty the better.  The energy is coming from the electrolyte mass and not from the creation of the electric field.  The spark gaps capacitance represents the loading of the input.  The anode is in common with the input "spike"-"kick" and the output rlc.  The output rlc is struck like a person striking a bell and modifies the amplified kick into lower frequency oscillations that is transformable to that needed by the load.  The anode is alternately used as a capacitor plate and a collector.  There needs to be a diode in the input circuit so that the electrons striking the anode do not create current in the primary.  A uv light scource irradiating the air in the gap and fired at the same time the electric field is established at the gap greatly enhances the probablitiy of the electron cascade effect.  As noted the photons that initiate the ionization are fluresced but they are acting as a catalyst.  Teslas ozone patent is a poor man's particle acclerator.  The electrons extracted from oxygen in a coronal discharge ozone generator result in large amounts of heat of both the emitter and the collector.  So much that the shell is most often water cooled. There is no current flowing between anode and cathode in a o3gen but large amounts of heat comes from somewhere?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
stivep
I have noticed that Russian forum Real Strannik is very conservative in judging the concept of new Kapanadze Replication down.
There are plenty very much scientific brains in Russia and  Satellites of Russia.
We will see what is going to be next.
Dear Mr King
One good side effect of your  team visit to TK  and later on complaining of how dishonest TK was is that we have so much of movement debunking TK device around the world.
And this is also because of you
Thank you
I was very cautious with wording used in my video
9/11 Universary, Scheduled to die....+ NO battery NEEDED OU
http://www.youtube.com/watch?v=QHBEHOOsxT4
I did not used images of 9/11 ...I did not give any chance to  those, who oppose and might   punish me for it.
Yes it was personal, It was important.
That would be a day when some of controversy of 9/11 will be discussed without fear of Feds knocking to your door as a result of it.
Wesley
Zeitmaschine
Work in progress, he bought a light bulb with 60 watts: http://www.liveinternet.ru/users/edward_lee/
Suggestion: While the device is still off shortcut all capacitors with a screwdriver to make sure there is no hidden energy anywhere in the device prior to start. Then switch it on immediately.
dllabarre
Quote from: stivep on September 13, 2012, 10:07:54 AM
Dear Mr King
Thank you
Wesley
Wesley
Thank you for the translation.
And your wife is beautiful!
Don
