JJUK
Hi jbignes5,
I may be slightly off the mark but given what you've just described, I think that you may be interested in the work of UFOpolitics at Energetic Forum http://www.energeticforum.com/renewable-energy/11885-my-asymmetric-electrodynamic-machines.html.
JJUK
Сергей В.
Quote from: itsu on September 14, 2012, 10:06:06 AM
Thanks for the encouragement T, but as i already was experimenting with coax cable coils, i already was intriged by this selfrunner.
I have a hard time understanding the Russian drawings/text etc, but slowly more info is coming in English.
My first attention is to the main coil, and i came up with the following info (all CW):
L1 = 820t 0.25mm on 4.6cm former (white/orange leads)
L2 = 315t 0.65mm on top of L1     (magnet wire leads to caps)
L3 =  41t 5.9m Coax cable        (probably NOT RG58 as to my knowledge RG58 is always black coated)
L4 =  72t                        (combination of brown and blue cable) not sure what thickness.
I started building my coil and use:
cardboard former 5cm:
L1 690t 0.4mm  3.3mH / 14.5 ohm
L2 380t 0.6mm  1.5mH /  0.5 ohm
L3  41t (6m) 75 ohm coax shorted at 1 end
L4  i will use 70t of some kind of wire i have laying around.
Questions for me presently are:
How to create this 1-5ns pulse (my FG generates a 80ns pulse at best)
What is the amplitude of this nano pulse (5v?, 500v?, 5Kv?)
What is the frequency/amplitude and pulse shape on the L1 coil (match the resonance frequency of L2 tank coil?)?
Video to be seen here:  http://www.youtube.com/watch?v=MQUciCy9p3A&feature=youtu.be
I will try to get more to the point in the video's, thus shorther, in the follow ups if any.
Next will be to make some measurements on the coil when pulsed.
Regards Itsu
Hi Itsu
Finally one serious man and serious researcher. I will help you with replication. In fact this is more research than replication coz there are many replicators and so litle researchers. Btw we on http://realstrannik.ru have big problems with KAPANADZE TROLLS (many of them are FROM KAPANADZE TEAM TROLLS) and OTHER TROLLS AND SPIES including flooders and spamers coz NO ONE GOVERNEMENT WANT FREE ENERGY DEVICE TO BE RELEASED. BUT will see. All options are in GAME opened and hidden. Will see !!
Problem was, Dalley oscillograph was burned in experiments so he wait deliver for new one oscillograph from China. I think will be some of 100MHz bandwidth dual channel oscillograph with accesories. So when oscillograph come will be complete measurements of all signals and signal envelopes. Dalley don't want to involve to many people in his project so other people oscillograph will not be used which is his smart move.
The time untill  oscillograph come from China can be used for making and experimenting with Nano Pulser, VCO (Voltage controled oscillator) and main Oscillator.
Dalley can't give all 100% specification coz he need to remove all windings and to precise measure all lenght and number of turns. So his decision is to make new one and original save like a sample for further research.
Antanas gave me a link and i was watching your video so i have seen you need some little help. And probably many other serious researchers so i write this message.
Coil Data:
About Coax. Coax is an original 50 om impedance, old Computer Local Area Network LAN coax. I give a specification for 50 Om RG58, coz it have the same impedance of 50 om, but i am sure you can use 75 om coax from TV sets for the first time experiments.
About 1st coil. The first coil was wounded long time ago and originally was a secundar of Dally's Tesla Coil experiment. Wire is according to him 0,25mm - 0.3mm magnet wire. I think you can use a smaller diameter than 0.25mm. Second coil or resonance coil is 0.65mm. Also i think you can use 0.6 mm as you have done.
And last 4th coil is from special avionic wire. The lenght is shorten coz Dally haven't got a wire for a full winding lenght so he have extended this wire with ordinary electric PVC wire. He was trimmed the lenght and he don't know exactly lenght of load coil. It's between 70-80 turns. This need to be checked but you can make here more turns till the end of plastic PVC water pipe. Put a more windings and later when trimming you always can cut remain of wire. This coils need to be very well isolated coz under this coil is HV coax bifilar coil. Use PTFE for isolation in several layers between coax and this coil. Later when you pump more HV pulses in Coax, isolation need to undergo more than 10kV HV peak nano pulses.  I think you don't need to keep exactly 1:1 specifications, coz this is research project and you always need "FREE SPACE" for your moves. Once when the principle was known and understood to you, you can make evertyhing you want !!
jbignes5
Quote from: JJUK on September 14, 2012, 03:42:47 PM
Hi jbignes5,
JJUK
Sorry but I will never step a foot back at that place ever. The owner of that forum uses it for his personal sales floor. I'd rather stay here and read posts from people who are not under the influence of that forum or it's owner.
Сергей В.
Itsu, about VCO on schematic.
VCO is standard well know type using digital logic. People which can't find original Russian logic circuits can use High Speed - Low Transient Delay- Logic circuits like HC, HCT, ACT, AS family. It's simple 2-input NAND gates. Use good and quality capacitors for Logic timing. Best variant are SMD components. The decoupling of all circuit must be done excellent this mean avoid close tracks of signal path to power line and use as much decoupling capacitors here to block noise and spurious signals. If you can do a shielding of all ICs by putting grounded copper stripe above ICs.  Reference voltage need to be stabilised and thermo  balanced. If you like you can use Special +5v Reference Source for trimming VCO. Use quality potentiometer with small resistors 10-20 om on the ends shunted with 10-100nf unipolar - capacitor to suppress noise from potentiometer. For Signal output from VCO use good 50 om coax and make a good gounding of shield (wire-mesh).
Zeitmaschine
Andrei Anatolievich Melnichenko:
The inventive method for generating energy by means of electromagnetic waves represents a process when electromagnetic waves emitted by one or several radiators operate into one load, or being previously accumulated in a storage are transferred to said load. During the generation process, the amplitudes of electromagnetic waves are combined in the load, the energy of electromagnetic field being a non-additive value is proportional to the square of the total amplitude of a field. Therefore, the energy released in the load is greater than the energy of each individual incident electromagnetic wave. Said load is disposed in the location of the in-phase combining of electromagnetic waves. The inventive device for carrying out the method for generating energy by means of electromagnetic waves comprises one or several generators of electromagnetic waves provided with radiators, power dividers and feeder lines, two or more radiators of electromagnetic waves operating synchronously into one load.
WO/2003/061110
Now kill me but does this description not fit a transformer (maybe three-phase) with two primary coils which operate synchronously into one secondary coil? Anyone has tried this yet? At least it would be simple, and this could also be the reason why there is no drawing in the patent specification.
According to this patent (or theory?) two electromagnetic waves (in a transformer?) in resonance to each other do not add up but potentiate their initial energy. Hence either it works as described or this patent is wrong. Who wish to find out?
Quote from: Сергей Ð'. on September 14, 2012, 08:42:53 PM
And you are absolutely sure Dally is not troll sent by Kapanadze in order to create distraction with his mysterious device because forums got too close to Kapanadze's very secret? :)
