0 Members and 113 Guests are viewing this topic.
verpies
Quote from: x_name-41 on September 15, 2012, 10:51:09 AM
Because output power depends of frequency and see one ATX inside and there you will see that capacitor is 1uF/400V!
Not even wrong.
The output power of this power supply depends on the transistor (2SC4106) switching frequency in the least.
It is much more dependent on the duty cycle of the waveform applied to primary winding as well as current applied to the primary.
The TL494 is not a Frequency Modulator (FM), it is a Pulse Width Modulator (PWM), which means that it accomplishes its regulating function by modulating the width of the pulses applied to the primary (a.k.a. variable duty-cycle).
The core's cross-sectional area, its permeability and saturation limit impose the engineering upper limit on the power transformation capacity of the T3 transformer.
semenihin-77
24 секÑ,ора на 1 обороÑ, ~ 300 кгц прерываний , движок 11000-33000 обороÑ,ов.
Плоская каÑ,ушка с нее съем.
МагниÑ,ные секÑ,ора залиÑ,ÑŒ эпоксидной смолой, не улеÑ,ели. Ð"ля безшумного режима жесÑ,кий диск оÑ, компьюÑ,ера, с драйвером , оÑ, него зависиÑ, выÑ...одная мощь, чем выше часÑ,оÑ,а, Ñ,ем больше Ñ,ока.  Ð"райвером можно управляÑ,ÑŒ программно, с заранее заложеными парамеÑ,рами скоросÑ,и вращения под конкреÑ,ную нагрузку (Чип памяÑ,и КАПАНАÐ"ЗЕ)
24 sectors 1 turn ~ 300 kHz interrupt engine speed 11000-33000.
Flat spool of her rent.
Magnetic sector pour epoxy resin, not gone. For noiseless mode the hard drive from the computer with the driver, it determines the output power, the higher the frequency, the greater the current. Drive can be managed programmatically advance Nasal speed parameters for a specific load (Memory chip Kapanadze)
wattsup
@ALL
I have been thinking about the mention of nanofrequencies or whatever you want to call it. When you send a pulse into a loop like a mobius that frrquency becomes multiplied almost to infinity because there is always a lag that creates endless overlays of the source frequency. We have all seen these in our experiments when your scope cannptlock into a stable waveform.
Again I always try to link theories with the practical physical proofs of the device we can see thus know it must fit intothose physical limitations. Now if we know the TKc blue wire has both the shield and center line shorted at the HV+ then that could apply as a pulse point to a mobius loop that has shield going one way and center line going the other way with the load being the series connection of both thus finalizing a mobius style pulsing method.
Guys again when you discuss theories it is always crucial that it points to the physicals of the TK devices otherwise anyone can say anything and expect others to make their own links.
Wattsup
jbignes5
 I wanted to go in depth with my theory and subsequent experimenting on the Old Tesla patents.
http://www.teslauniverse.com/nikola-tesla-patents-381,970-electrical-distribution
That is a special transformer Tesla designed. If you read the text further down in the descriptions you will find this comment:
"The combination, with a core closed upon itself, inducing or primary coils wound thereon and connected up in independent pairs or sets, and induced or secondary coils wound upon or near the primary coils, of a generator of alternating currents and independent connections to the primary coils, whereby by the operation of the generator a progressive shifting of the poles of the core is effected, as set forth."
The part where it says "and induced or secondary coils wound upon or NEAR the primary coils"
The Generator designed by Tesla in the previously shown patent has the Secondary(Rotor) of the transformer wound near the primary. This is the premise I am running with in implementing the patent the way it should have been. Instead our current generators were bastardized and modified to suck as much current as possible. My take on this is if you have a commodity you want to design inefficiency in the units to make the commodity more valuable and increase your income from that commodity.
In reality if we read Tesla's notes on this form of electricity you will find that it doesn't induce anything but actually is excited by the electric field. If there is a magnetic field it would only work against the generation part of this dynamic transformer. Indeed if this form of energy is static then we must apply rotational momentum to get it to supply current.
