0 Members and 38 Guests are viewing this topic.
hartiberlin
@baroutologos
could you please post a circuit diagram for your last tests with the
LC circuits ?
Only from your pictures it is hard to see, what you have done.
Many thanks again for your experiments.
Regards, Stefan.
baroutologos
I am sorry for the obscurity. Below are the component values tested.
Same power level voltage levels (spark-gap length) and load for both experiments.
ps: You are welcomed!
allcanadian
@Baroutologos
QuoteI am researching, i am always open to suggestions and i do not take the bull in consideration.  I admit that do not have all the answers. If i had i would not bother at talking to anyone.
I have faith in logic and all thing can be explained that way. By way you have a good argument there. Why i keep doing this... it's my nature i guess to search at the grey zones. Its fun.
To be honest I think your doing a great job and with determination you will succeed, we can only fail if we give up on ourselves, as well if I thought you had no idea what you were doing and were hopeless I would not have critized your post. Im not sure if this will help but many times I have found insight using what I call anti-logic, logically you cannot get something from nothing the inverse of this statement is that you cannot get nothing from something. However we know we can make something appear to be nothing when we burn wood and it disintegrates into gasses and heat. Therefore our free energy device must utilize the natural process of integration (putting things together) not disintegration(taking things apart). Integration would be Zero=+1 and -1, Desintegration would be +1 and -1=Zero, the product would always appear to be zero but this is only because nature always seeks to balance the equation. There lies natures secret, she will not tolerate imbalance and continually moves to correct it but at the same time she can never truely find it. She is tormented for eternity looking for stillness she will never find in a universe full of chaos. You see whenever she moves to correct the imbalance this very motion creates more imbalance, it is a hopeless task but that is her nature.
AC
xenomorphlabs
I am still trying to figure out how the blue coil structure in SR´s video is assembled.
Everything that i can see above the table is
1) the tiny cable coming from the spark gap that runs over the core
The bend at the insulation tape entry point suggests that it is indeed
wound like a coil above the core
2) a thick cable coming from the emitters of the transistor pair that connects
    to the middle section of the coil structure
3) a thick cable exiting the middle section of the coil structure bending around the whole thing and leading UNDER the table
4) a less thick cable entering the core cable strain to ground from the left side
So 2) and 3) seem to be the primary and 4) one side of the secondary where i fail to spot the other side.
The primary appears to be like a center tap primary, but i suspect that it is only one winding with only 2 ends.
The question is if the windings visible on the left side that make this thing look a bit antisymmetrical are part of a tertiary winding of some form or maybe he just needed more windings to reach the needed output voltage.
From what can be seen, i have a hard time understanding this as a transformer. If i remember correctly SR said that he has another 20W transformer connected to the output of the blue coils.
Why would he do that if he could design the winding ratio of the blue coils
accordingly?
Does anyone see more cables entering the coils?
baroutologos
In continuation of my small experiments stimulated by Admin, i remake my setup so as the receiving  this time to be of higher inductance than the previous one.
Winding A same (133uh) new winding B, 125uH. Variable inductance with insertable core 4-25uH.
In this setup i failed to observed any noticeable resonant action at the receiving LC. Potential cause could be the ferrite core. I changed the capacitors (in case my small 4Kv 50uf, Teflon caps are defective) but no change in effect.
In any case, still I fail to view any OU effect in resonant reception to a load. By the way one signifficant advantage of this apprach is that the load can be impedance matched.
ps: experiments1 are without LC resonant reception
