0 Members and 27 Guests are viewing this topic.
itsu
Quote from: Сергей Ð'. on September 17, 2012, 12:41:10 AM
Itsu now about DALLY device.
Сергей Ð'.
Thanks for all this info, its kind of hard to find substitutes for these Russian parts.
I will try out your suggested coil measurements as my induction meter only works on 1 frequency.
PS, i have a 1:1000 probe on order.
Good memory you have :-) , no Owon did not fix it as they wanted me to send the scope to China to upgrade the firmware and i did not want to miss my scope for severall weeks.
By the way, it was not really a bug, just the inability to present math. figures instead of math. traces.
Regards Itsu
verpies
You can connect in series several diodes for example 4 -10 and more to get Very High Voltage Nano Pulse. For more forward current make a parallel conection on several series diode.
Only if the avalanche transistors or diodes experience avalanche breakdown at the same time.
If they avalanche sequentially, then their rise-times will add up and consequently the slew-rate of the pulse will decrease and sub-nanosecond pulses will not be achievable anymore.
verpies
Quote from: starcruiser on September 16, 2012, 07:23:57 PM
I do not think we require 10kv pulses but more around 300 to 500 volts which could be controlled by IBGT's or MosFETs perhaps. This is what they are putting on to the coax per the diagrams floating about. We need to worry about the freq response of the semi conductors under consideration.
That would be good news. 500V/ns is almost doable.
@Sergiei
What's the amplitude of those sub-nanosecond pulses feeding the coax?
itsu
Quote from: d3x0r on September 17, 2012, 04:12:47 AM
Please more about the torus Tr2
d3x0r,
from one of the diagramms i have printed out (i don't find it anymore on the forums, as it seems that data/diagramms are coming and going),  i have got this info:
Ferrite Ring probably 4cm od
Windings 1 and 2 are  3 turns 1.5mm
Windings 3 and 4 are 70 turns 0.6mm
Perhaps this can be confirmed by others.
Regards Itsu
d3x0r
Quote from: itsu on September 17, 2012, 05:16:29 AM
d3x0r,
Ferrite Ring М6000НМ К7mm Ñ... 4mm Ñ... 2mm
Regards Itsu
I thought that was the transformer for Tr1; the text in the same block relates to the KT926  (it's on the overall schematic)....
I may be way off, but 7mm is a lot smaller than that toroid which is as wide as two pots .... (although I might by the turn ratio of 3 and 70)
