0 Members and 101 Guests are viewing this topic.
jbignes5
Quote from: Hoppy on September 17, 2012, 11:53:17 AM
As one of those on this group that has flung an accusation of fraud on the Kapandze device, I am also a person that tries to replicate and am indeed so doing with the Russian Daly device. Given that there is very little to base a replication on with the Kapandze device and that no hard data is available for it, it is little wonder why it has been labelled as a likely fraud. I certainly do not have the time or money to attempt replications of devices based on sparse information and will always first consider the likelihood of fraud until decent build information etc., is forthcoming. IMO, the Kapandze motor generators are likely frauds in that the second and third devices are probably powered from a concealed motor underneath that belt couples to the main axle within one of the bearing block housings. The first motor shows signs of there being an electrical contact on each disc which could pick power up from concealed battery. Having made this assessment, its difficult for me not to think that trickery could have been applied to the TK solid state devices.
Just because a few people look first at possible methods of fraud, it does not follow that those people are necessarily trying to put down all FE claims. I for one have the same passion as others on this forum for finding a means of freeing the world from the oil barons, I just approach FE claims investigation in a different manner
Hoppy
No you assume fraud. That is all. No wonder he isn't here defending himself and answering questions and providing information. Why would someone come here to face BS claims of fraud with no proof as such but just imaginations. I agree that there needs to be more information but you and others have pretty much assured that he won't come within two inches of this forum. So even if the devices are true you'll never know will yah... All you are going by is wild imaginations and not proof of anything. You and many others have assured that we can't even ask questions at all simply because the man does not, I will imagine, want to deal with all the crap.
You method is nothing but BS. It's not even scientific and you admit that yourself.
Anyways what does this Dally thing have to do with Kapanadze devices? I don't remember it saying Dally device as the thread title....
Also what does due diligence have anything to do with assuming something is a fraud? There is no diligence if you do nothing but assume.
d3x0r
Quote from: jbignes5 on September 17, 2012, 09:46:08 PM
I'm glad it wasn't a new thread I would have entirely missed the clues.  This IMHO is exactly the same as kapanadze, and is a good replication, if slightly modified.  The kapagen is a black box in a lot of ways, and I've seen a lot of theories thrown around.
Well hell, someone said ferrite cores were no good for nano second pulses... but it's a 7x4x2 toroid... and one thing I did learn from joule thieves, the size of your core determines a base frequency.  And made me question some things; but I found [size=78%]http://slac.stanford.edu/pubs/slacpubs/11750/slac-pub-11853.pdf[/size]  which has
".... [size=78%]The [/size][size=78%]expected relaxation time for ferrite in the strong magnetic [/size]
acting fields is ~ 40 psec and this is a physical limitation
of the core material. ...... "
So ya, it might help shape the pulse, but it is definitely able to transfer it.  Plus it's a mono-polar pulse; so you're never working against the flux left in the core... And actually, that will help squelch the back pulse....
In my replication, I've made the coils on separate, nested formers.  (my 28 gauge driver is on a pvc tube and that fits snug in another pvc (which outer diameter is like 3.8 instead of 4.6), which has the resonator, and I should re-wind the outer coils... but a 6m length of 50ohm coax, and ad the outer pickup is on a separate tube.  Using a frequency generator, was confirming that merely sliding the position of these coils will affect the resonant frequency, and should provide a good tuning point. So it's not TK or Dally, what of it?  It's more of a solid state device than TK.
So if you have a high potential field, and during that field, produce another high voltage pulse that goes from one end to the other, and reflects to come back the opposite direction... something about interfering electromagnetic fields...  (giving an avalanche pulse just before the peek of the other pulse?)
Hoppy
@T-1000
Thanks for posting the coil details. This takes away the guess work. I like his coil former - a decorators silicon sealant tube  :) Now onto some finger aching winding.
Hoppy
verpies
Quote from: d3x0r on September 18, 2012, 03:38:37 AM
And made me question some things; but I found http://slac.stanford.edu/pubs/slacpubs/11750/slac-pub-11853.pdf[/size]  which has the expected relaxation time for ferrite in the strong magnetic acting fields is ~ 40 psec and this is a physical limitation of the core material. ...... "
This article is a good find.  It acknowledges that traditional multi-turn pulse transformers with a ferrite core are only good up to 100MHz (>100ns pulses).
According to this article it is possible to step-up the voltage of a sub nanosecond pulses using a multi-core fraction transformer.
Does the Dally design use such an exotic transformer?
Quote from: Anatoly Krasnykh
An induction system comprises an array of single turn pulse transformers.
Ferromagnetic cores of transformers are toroids that are stacked along the longitudinal core axis. Another name for this array is a fraction transformer or an adder.
The primary and secondary windings of such a design have one turn. The step up mode is based on the number of primary pulse sources. The secondary windings are connected in series.
Performances of such a system for the nanosecond range mode operation are different in comparison to the performances of traditional multi-turn pulse transformers, which are working on a 100+ nanosecond mode operation.
In this paper, the author discusses which aspects are necessary to take into account for the high power nanosecond fractional transformer designs.
The engineering method of the nanosecond induction system design is presented.
verpies
Quote from: Hoppy on September 18, 2012, 03:59:13 AM
And only plastic dispenser tubes manufactured in Prypiat will exhibit any anomalous effects when used as a coil former/bobbin ;)
