0 Members and 85 Guests are viewing this topic.
leo48
8)
Ok from my experience and the size provided to me by Bernhard I can tell you that this is a three-phase transformer
with a maximum power when used at 50 hz to 400 watts and the 17-ohm winding is suitable for 'power to 380 volts,
the coil by 0.5 ohms is a low output voltage to 12 volts and probably the winding from 79 ohms is a high-voltage
output about 2000 volts.
What can serve as an output to 2000 volts in a computer? could be used for in dust filters coupled to the
cooling fans of the tabs ..
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
wattsup
@leo48
Consider that the primary on each is the 0.5 ohm coils. Also in the Aq2 device the three transformers at terminals #3 and #4 are all paralleled together. The right transformer (C1) pin #2 (HV-) goes to the same C1 pin #3 so there is no HV- going to the output, It is basically riding inside the three paralleled coils. Just the terminal #1 HV+ is going to output. But that last part has to be tried still in various configs.
So in your assessment, please consider the primaries as being the 0.5 ohms coils. Also consider the #3 and #4 of each of the three are in parallel and going nowhere.
wattsup
PS: If after all the above, the output would still be around the 2000 volts level, then I am wasting alot of time with my flyback transformers that are easily above 10kv, and will have to find a lower voltage output, that may explain many other factors of the overall effect.
sparks
  TK obviously cannibalized a television set.  I believe Stivep did also.  TK buries a copper radiator and pours water all around it.  Tesla at Colorado springs buried metal and watered it in seeking to establish a lightning rod.  Tesla invented particle accelerators before vacuum tubes were available.  Tesla also claimed that radiation burns from his devices were ozone burns.  UV radiation ionizes oxygen to O3.  Uv is generated in an accelerator upon acceleration and deacceleration of electrons.  In an electron cascade event the electromagnetic energy produced is thousands of times that of the beta radiation that initiates the cascade.  The accelerated electrons have inertia and will continue on and deaccelrate upon striking the anode.  The accelerating field has come and gone in nanoseconds while the current pulse experienced at the anode continues on at intensities and duration far in access of the energy needed to charge the gap.  This procedure say picksup 1000 electron volts/fire.  As  the frequency of pulses is increased we see that so isn't the gain.  If we are operating at 10k pulses per second you can see how a gain of millions of electron volts is possible.  The higher the frequency of pulses the more gain.  The larger the accelerator the more gain.  The mt. in wardenclyffe was the largest electrode I have yet to see.  The few times Tesla tested it locals could see the glow zone all around it making energy out of thick air's electronic inertia.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Ganzha
Dally is a fake for thrue
he appears and start collect money from russians
He shows not relable  video and never show this device for long time but for short (1-2) minutes. T-1000 possible Dally himself or his agent or agent of TK//// It  looks like a way to takke attention of people and foolish them.
Dally said that he going to destroy main coils - the reason to know exact number of windings..... and he did it without any oscilloscoping outputs and any kind of measure inductance of coils.... Now he should said ok i know how much windidns I got but///// the old device is not working after rewinding but I dont know why.... but we spoled out time and weisted our money for nothing
T-1000
Quote from: Ganzha on September 19, 2012, 01:02:46 PM
Thats just stupid to accuse. I translated into understandable form and thats it. If you will do more insults, your posts will be moderated and cleaned by moderators. Thank you for your disrespect to people.
